Old 26-May-2006, 09:25   #21
iang iang is offline
iang's Avatar
I have just fitted an underslung rear caliper bracket on my 749R and I cannot bleed it so it looks like I will have to lift the caliper as suggested to bleed it.
Cannot be as bad as the 2 days I tried to bleed the brakes and clutch after I fitted the cycle cat riser kit. I could not get any fluid to come through even using a hydraulic bleed kit from a local dealer, after taking the system completely to bits, guess what it was !!!!!!!
Yes, the plastic reservoirs had plastic bungs in them that I had failed to spot when fitting them, 15 minutes later the job was finished !!!
[Edited on 26-5-2006 by iang]
Old 26-May-2006, 09:37   #22
khushy khushy is offline
khushy's Avatar
you mean you fitted the reservoir hose on top of the plastic bungs???
maybe you should NOT be pi*sing around with your brakes - ever thought of that??
[Edited on 26-5-2006 by khushy]
Old 26-May-2006, 09:48   #23
Murray Mint's Avatar
Oh I very nearly did the same thing once, thought the hose felt a bit tight.
Old 26-May-2006, 09:52   #24
khushy's Avatar
scary!!!!
Old 26-May-2006, 09:55   #25
khushy, I keep looking at your avatar and wondering what it's all about.
Old 26-May-2006, 09:57   #26
khushy's Avatar
have guess - what do they look like?
Old 26-May-2006, 10:02   #27
khushy's Avatar
is that better?
Old 26-May-2006, 10:07   #28
Antthing to do with Rossie?
Old 26-May-2006, 10:09   #29
khushy's Avatar
good job you can spell!!!
who is Rosie??
Old 26-May-2006, 10:16   #30
OK if you want to be cryptic then so be it, if you want to tell me what its all about then do so or don’t……
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:44.
