Alarms and Related Security
Old 27-May-2006, 12:19   #1
Rossman_999 Rossman_999 is offline
Water and Alarms
Yes I know I should not be riding in the wet, but with the weather being so changable there is sometimes no option
After heavy rain (or washing) I cant set the standard Datatool on my 03 999BP as it starts "ticking" and after a few minutes the alarm activates which really pleases the neighbours!
So today got the tub of vaseline and electrical contact cleaner and proceeded to spay and stuff every connector I could find -Happy with my mornings work I decided to test it and lightly hosed the bike and yes the alarm went off again.
Have I missed one? or do "THEY ALL DO THAT!!"
Ive seen posts on this before and ive searched but cant find them.
Help!!!
Old 27-May-2006, 12:44   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Yep. They are crap. I have similar issues with the Datatools on my road-going 800ss and on my Triumph. They don't like water - you might want to check the gasket sealing the alarm case. They can fail.
Old 27-May-2006, 13:54   #3
andys 900ss's Avatar
Mine went up in smoke after washing the bike down.
Its the main unit that lets the water in and its really hard to stop water getting in where the cables enter the unit. I might be a good idead to mount the unit where it cant get wet or cover it in cling-film, although it might not be that load then!!!
Andy
Old 31-May-2006, 17:36   #4
B19PSK B19PSK is offline
Bikes: 998S and MTS1200S
B19PSK's Avatar
Mood: Growing old disgracefully, DSC member 2387
Talking Conformal Coating
Once the alarm is installed and working correctly.
Carefully remove the lid (Torx) and seal up the cable entry as much as possible (Silicon sealer) then spray "Conformal coating" on both sides of the PCB and connector (with the wires attached). This will coat the electronics is a plastic coating making it much more waterproof. While your in there replace the NiMH battery for a new one at least 2100mAH size or better, £3-4 on Ebay. Any probs on the Conformal contact me.
Regards
Old 01-Jun-2006, 20:28   #5
Regards
Many thanks, ill open it up at the weekend and give it a good spray, Im surprised the alarm PCB is not encased already in plastic.
Whats the point of the bigger battery?
Old 08-Jun-2006, 06:53   #6
duck duck is offline
duck's Avatar
mine plays up as well. if it rained really heavy it would bleep once occasionally while i was riding and then randomly set itself off for an hour after i'd stopped.
spoke to datatool and they said...it's probably water in 1 of the connectors though not necessarily the alarm itself. it could be detecting a current change from water in 1 of the bikes connectors and triggering the alarm.
now if i pull after a heavy shower i let it tick over till the fans come on to try and evaporate the water, touch wood it hasn't done it since.
Old 26-Nov-2006, 17:35   #7
B19PSK's Avatar
Lasts longer if they (thieves) disconnect the bike battery, generally the higer capacity batteries are from better manufacturers. They only have a good life of 2-3 years, 4 at the most.
Old 26-Nov-2006, 18:29   #8
Depending upon the model of alarm, there could be a few "upgrades" available.
The early evo + alarms suffered with water entering through the siren. There is a new cover available with a sealed unit fitted.
The later alarms have a potted circuit board that is very reliable. These are usually retro fitted under warranty circumstances. If the alarm is still warranted, it may be worth a call to your installer.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:38.
