Old 22-May-2006, 14:47
fraggle fraggle is offline
Mood: The 996r is back on the road!!!
14t front sprocket for 916
Is replacing the standard front sprocket on a 916 with a 14tooth item a good thing to do? I have heard that it will change the acceleration and driveability??
What pitch chain is the exisitng item? 525 or 520??
Thanks for any info.
Old 22-May-2006, 14:50
yeti's Avatar
yeti yeti is offline
You might find your 916 is already on a 14T. If it's on a 15, then swapping will increase acceleration. Standard chain should be a 525
Old 22-May-2006, 15:24
Totto Totto is offline
Yep , quite a common mod , means you can actually use sixth gear
If your chain needs replacing soon best go up on the rear rather than down on the front
But if the chain is good then 14 on the front is ok ,but is more stressfull on the chain than going up on the rear
I have mailed you a gearing chart that was posted a while ago by another member , dont know who though , but thanks to whoever it was
[Edited on 22-5-2006 by Totto]
Old 22-May-2006, 15:40
Thanks for the info guys, much appreciated
Old 22-May-2006, 15:48
Carbon749's Avatar
Mood: I own a flame thrower
I know this conversation has been done before, but, the current 749S probably puts out similar power to an early 916. 749's come with 14t front sprocket as standard.
Therefore with my limited knowledge I would say fitting a 14t to an early type standard 916 will be no more stressful to the chain than the current 749S is.
Old 22-May-2006, 16:27
I know , guess what i run on my 998 , yep a 14 tooth front
Old 22-May-2006, 17:09
zhed44's Avatar
zhed44 zhed44 is offline
Mood: YELLOW!!!
At the risk of hijacking the thread, I'm going up 2 on the rear of my 748 pretty soon - will it be fun?
My B600 is down 1 tooth on the front and it's like sh*t off a shovel off the line and through the gears - just ask the owners of the Ferrari 355 or the 911 4S it's creamed in the last couple of months :P......but it will only do about 95mph now (not that you'd want to go any faster than that on a nekkid)
Old 22-May-2006, 17:13
CipiVTS's Avatar
CipiVTS CipiVTS is offline
The 748 has 14/38 as standard.
I would go 3 teeth up on the back to really make a difference. Anyway, you will have to fit a 96 link chain
Old 01-Jun-2006, 19:06
DUCMANs's Avatar
DUCMANs DUCMANs is offline
Try the Gearing Commander
Try this: http://www.xs4all.nl/~ator0437/gc/ to see the difference between going down 1 in front or 2 or 3 up in the back.
Regards, Jean
Old 01-Jun-2006, 22:03
CipiVTS's Avatar
Thanks for the software. I didn't know there is so much difference even by changing the rear tyre.
I have a 916 with 2:1 primary ratio, 14:36 sprockets and a 180/55/17 rear tyre.
With the 180 profile is overgeared comparing to the 190 profile. I have a standard box that cracked so i will fit a close ratio (748) one.
I'm really curious how it will be?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:26.
