  #21
Old 01-Jun-2006, 23:55
Andy lives across the road from the BMF at Peterborough which is why we had the pleasure of his company a couple of weekends ago
  #22
Old 02-Jun-2006, 10:56
Dominic Clegg's Avatar
Originally Posted by phil_h
I think you have to change one thing at a time now, starting with swapping the plugs from front to rear, to prove that each pair of items will work on the rear cylinder - even a new plug can be duff.
You havnt mentioned the carbs - have they been apart ?
If so, are both the diaphragms working properly (you can test by hand by carefully pushing them against the springs) cos that may well stop one starting (!)
Have you flushed the float bowls to make sure its not water making the plug wet ?
If you flushed the float bowls was there any muck - cos that might have blocked the pilot jets.
Have you tried a squirt of special starting-juice (cant remember what its called) into the front when the back is turning the engine over ?
time for bed now
good luck
phil
btw - where are you in case someone wants to come round ?
its called start you *******
  #23
Old 02-Jun-2006, 11:37
domski's Avatar
'Easy Start' is the thing. Not sure if it will help here though. Somfing clearly aint right.
  #24
Old 02-Jun-2006, 12:06
phil_h's Avatar
phil_h phil_h is offline
THATS the stuff
  #25
Old 02-Jun-2006, 13:10
have you got old fuel in the tank. are you flooding the cylinder have you replaced the ht leads and cap have you cleaned the carbs thats all i can think of if not have a look at this
http://cgi.ebay.co.uk/Ducati-600cc-E...cmd ZViewItem
good look mate by the way did i borrow your foot rest at brands
  #26
Old 02-Jun-2006, 14:06
Andy C Andy C is offline
sure did, are you gonna give it back. did it survive the crash LOL. Only joking, don't worry about it mate you can keep it.
  #27
Old 02-Jun-2006, 14:12
i bent mine back still got yours hope to see you at cc and i can give you it back.
have you changed the poston rings
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:37.
