Old 27-Jun-2006, 09:57
beancounter's Avatar
Forking Fork Seals
I have 3 Ohlins equipped bikes and 3 sets of weeping fork seals.
They do say things come in 3's (is it good things or bad things?)
Before I trek up the A5 to Baines and empty my wallet on the counter, can anyone recommend anyone closer / cheaper who can do this kind of work (as of last week I'm based in Leighton Buzzard).
Thanks
BC
Old 27-Jun-2006, 11:13
khushy's Avatar
khushy khushy is offline
there is an updated seal that is a vast improvement on older items!!!
Khushy
Old 27-Jun-2006, 11:17
Harv748's Avatar
Harv748 Harv748 is offline
Ditto Khushy...my ohlins have let go on both sides, and both have been replaced with the 'new improved' version...no problems to date whatsoever.
Also...really obvious, but ensure that the new seals are greased on fitting. They should be lubed to help them 'bed-in' for the first few miles. This must obviously help them initially, but I would imagine also in the long run.
Old 27-Jun-2006, 11:19
Thanks guys, but who does the work? This can't be a diy job...
Old 27-Jun-2006, 11:37
851neil 851neil is offline
Mood: need a bike...
it can be a diy job, but like all jobs there are a couple of tools you would need, there's an ohlins web help line with an excellent set of instructional manuals showing how to get the job done + it provides detail of the tools you would need.
http://www.ohlins.com/mc_manuals.shtml
Old 27-Jun-2006, 11:41
Thanks Neil, I put air in my tyres but that's about it.
I'm looking for Ohlins / suspension specialists in the area.
Old 27-Jun-2006, 11:57
lol - I like it...being from oop north can't help with that one I'm afraid, have you tried a yam dealer ??
Old 27-Jun-2006, 13:11
bitchinSP4 bitchinSP4 is offline
You could try Harris performance in Hertford. They rebuilt mine years ago, sorted out a balls up by persons who have been mentioned!! The seals did go about a year or so later and they sent me a set which have now been fitted for at least 6 years with no probs.
Mike.
Old 27-Jun-2006, 18:01
Gaz 748's Avatar
Talking
Mine where leaking, now there ok !!!!!!
748R - Less is more !
Old 28-Jun-2006, 08:47
If you can't be bothered to change seals or it's a really minor weep then a trick that sometimes works is to take a thin piece of old OHP acetate, cut a pencil type shape and feed the 'sharp' end up under the seal, once under the seal run it all the way around the fork leg - pullling it out as you go.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:45.
