Old 18-Jul-2006, 18:02
pibbow pibbow is offline
Mood: Very sad
888 It Stop Working!!!!
Well it's me again, out on the bike this morning did about 20 miles and she stopped and would not fire up again. loads of power in the battery, checked the fuel relays all ok there, I've got power to the 4 pin plug under the tank but the pump dose not prime when I switch on the ignition. any ideas I suspect the fuel pump but could it be something simple (Cheep)!
Peter
Old 19-Jul-2006, 11:59
Mood: Very sad
Unhappy
Anybody
Old 19-Jul-2006, 12:00
beancounter's Avatar
Can I refer you to the DuN board?
They're very helpful.
Old 19-Jul-2006, 12:19
Mood: Very sad
Question
I have to agree with you mate is it cos I'm in the norf
Old 19-Jul-2006, 15:41
DaveB916
Not sure if the 888 electrics are similar at all to 916? but had same with mine
a few evenings ago , same symptons etc. was a secondary fuse under the seat for the ECU, the holder had water ingress and had just corroded away new holder and fuse and hey presto !!
No power to ECU no power to fuel pump.
Old 19-Jul-2006, 16:00
Where did the reply I posted go
___________^
Old 19-Jul-2006, 16:43
Have you got 2 powers on the 4 pin plug? There's a feed and earth each for the fuel sender and the pump.
If you do have power then the pump looks like being the suspect
Old 19-Jul-2006, 17:19
neil neil is offline
You could try wiring the pump directly to the battery to see if it turns. I've had it with a car where I had voltage at the pump, but it wouldn't work, it was down to the inability to supply current due to a corroded fitting.....worth a try?
Old 21-Jul-2006, 11:05
Mood: Very sad
Thanks for your input lads It turned out to be water in loom = blown fuse so not so bad as I thought.
Regards
Peter
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:44.
