Old 22-Oct-2003, 13:14
Scaramanga Scaramanga is offline
Mood: like a fresh jelly: Not Set
Changing the head angle
Hello there peeps,
Just wondering if anyone has sharpened up the head angle for road use. If so what difference does it make?
Any thoughts would be gratefully received.
Cheers,
Simon
Old 22-Oct-2003, 13:57
Steve Steve is offline
Do a search there has been plenty of discussions on this
Old 22-Oct-2003, 14:18
Totto Totto is offline
Check the old board , there was a massive thread , read it & make you own mind up as there are pro's & con's
Iwas on the steeper angle but back to normal for other reasons !
Old 22-Oct-2003, 15:36
998Addict 998Addict is offline
Mood: Pensive
As Steve says, read the discussion threads on the old board. For my money though, the steep head angle is the way to go for both road and race - I find jacking the back up tends to raise the rear under heavy braking.
Old 22-Oct-2003, 17:03
Stability and Steering Angle
The central issue with making this change is stability. A motorcycle is designed to return to its straight-ahead condition after hitting an object or bump in the road that causes the front wheel to deflect slightly to the right or left. In other words, it has to remain stabile for a variety of road conditions, and motorcycle stability is foremost a safety issue.
The way dynamic stability is maintained is to design a bike with enough distance between the point where the front wheel touches the road and the intersection point between the steering axis and the road. This is called the trail dimension.
A longer trail dimension increases the motorcycle's stability on straights, but will also negatively affect the motorcycle's handling, i.e. more rider's strength is required in corners and transitions. However, the more trail the greater the ability of the bike to self-correct it's steering. It's a longer trail dimension, for example, that allows you to easily ride with no hands on some bicycles but not others.
A shorter trail dimension, on the other hand, produces a lower opposing force to steering inputs. It's kind of like power steering. So the steering requires less rider strength, but higher handlebar displacements from bumps in the road and corners are fed back to the rider. Said another way, the shorter the trail the more rider input that is needed to hold a line and the more responsive the bike feels since it is more sensitive to steering inputs.
The two superbike steering angle positions, 23°30' and 24°30' produce trail dimensions of 91mm and 97mm respectively. The wheelbase, also an important factor in stability, remains unaffected when you change it. As a comparison, the Monster steering angle is fixed at 24° and the trail dimension is 94mm. Adjusting the trail dimension on most manufacturer's bikes is not an option.
As an aside, when you change to the steeper 23°30' position you loose a significant amount of steering lock making low speed U-turns more difficult. Also, the ignition steering head lock doesn’t engage in the steeper position.
Now, here's Ducati's warning: "Trail should only be altered after all the other (geometry and suspension) changes have been made and you are comfortable on the bike. If the bike displays any instability problems they need to be sorted out first, as this steering head angle change will magnify these characteristics."
(One reason, for example, is that part of its effect mimics changing the rear ride height.)
The Haynes Service manual goes on to say: "Warning: The steering head angle must be set to the road position (longer trail) whenever the bike is used on the road. If the steering angle is set to the race position (shorter trail) ... the handling of the machine could become unpredictable on uneven road surfaces."
So, shortening the trail is considered unwise for street riding (unlike tracks) where bumps in corners, potholes and other road hazards repeatedly challenge your bikes steering stability. Here's a case where inexperienced or uninformed riders who set-up their street bike chassis geometry as racebikes are just looking for trouble.
Trying to mimic factory race bike set-ups can get you into difficulties. It's central to racing that race bikes often need to sacrifice high-speed stability to handling. Riders may initially run the steeper steering head angle but often, as they get faster, they realize they want more stability, not less.
To get more stability there are two things that Ducati typically changes on their racebikes: the triple clamps and the swingarm. They use triple clamps with less offset, typically 27mm instead of the stock 36mm, and use a 25mm longer swingarm to increase the wheelbase. These changes to the triple clamps or the swingarm have the effect of moving the center of gravity forward which is the typical starting geometry of the Corsa race bikes. Remember, changing the steering head angle does not, by itself, change the wheelbase or alter the center of gravity.
Some here have suggested that you can get the same effect (reduction in trail) with a finer adjustment by increasing the rear ride height instead. However, you'll need to raise rear ride height 16mm to get an equal amount of trail reduction, and in doing so you'll also end up increasing the height of the bike's CG by about 12mm that (among other things) will increase loading to the front tire, so when hard on the brakes, the rear tire gets/feels very loose.
Another area of major concern is tankslappers. Reducing trail by reducing the force that centers the front wheel will give you more headshake, especially when accelerating (less weight on the front wheel) out of bumpy corners.
You won't get a tankslapper out of most corners if you change to the steeper steering head angle, but you will make them more likely, and more violent, when they do occur. Some will say to crank-up an adjustable steering damper to settle the steering, but dampers will only resist changes in steering direction and don't provide a restoring force to re-center the wheel like trail does. The higher damping rates also spoil your quick steering and cause weave instability problems when cranked-up too high.
Old 23-Oct-2003, 16:13
Bungi Bungi is offline
hi simon
When i was running the bp and my 996s having used the bp for trackdays changed the steering head angle where as leaving the s standard, i much prefered riding the Bp on the road in comparison to the s, streering BLaH BLaH,
The biggest down point is the lack of turning circle which is really noticable.
I did not encounter any significant stability problems, and those I did, i managed to ride through them, however the BP was running on rensports at the time which are a fairly stable tyre, not sure how much differance other tyres may make.
there are so many variables which need to be considered for the road, perhaps any desired handaling effects can be produced by having the bike set up correctly to achieve what you are seeking, ie ride hight and suspension settings.
arent ducatis wonderfull, the more you look into them, and become involved, the more complex they seem.
For me the limiting turn circle is not bearable on the road permanantly, but Id definatley use the steeper angle every time on track.
so the next thing will be the ohlins rear then ????
regards Bungi
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:02.
