Old 24-Jul-2006, 17:15
NBs996's Avatar
NBs996 NBs996 is offline
Mood: I love my 996 xxx
Question Here's my problem...
Right then, it's probably electrical so I'm lost... hope someone can help:
Riding along quite happy, then the engine starts to pop and misfire.
Shortly after, the engine is on/off, like surging and dying repeatedly.
Pull over and it dies.
Re-start her and tickover is as smooth as yer bum, but slowly increase the revs (in neutral) until it gets to around 4k then it dies. Release throttle and it catches again at tickover and it ticks nice n smooth.
Leave it 15 mins, fire up, ride off - all fine and dandy again.
Whatsgoingon????!!!!
n
Old 24-Jul-2006, 17:18
Rattler's Avatar
Rattler Rattler is offline
Mood: www.cantbearsed.co.uk
Ghosts in the machine - argggggghhhhhh !!!
Old 24-Jul-2006, 17:29
madmav's Avatar
madmav madmav is offline
Bikes: 1098
Mood: Chilled
Wink
sounds like fuel starvation Nick! Blocked filter or even pump/relay!! hard one to find"" Nelly bring it on?...mav
Old 24-Jul-2006, 17:43
wato39 wato39 is offline
Mood: Saving
I had a very similar problem a few weeks ago and it turned out to be the pressure sensor . Good luck
Old 24-Jul-2006, 18:10
NBs996's Avatar
Ta guys (no, not u timothy!)
Fuel starvation was my suspicion, but i'm not sure that ties up with the on/off power (it's either 100% on or 100% off, not nufink in between). Blew through the filter, a very technical check that was, and it seemed clear. No splits in the short tubes connected to the pump either. Could it be the relay, or is that only active when the pump is primed?
Pressure sensor - d'you mean the air pressure sensor?
If only it was a mechanical prob, then it'd be a piesh of pish!
Old 24-Jul-2006, 23:32
GsxrAge's Avatar
GsxrAge GsxrAge is offline
Check your fuel tank breather !!
Old 25-Jul-2006, 00:00
came across a similar problem once, turned out to be the cranksensor, the hotter the engine oil got the worse it was, and the hihger you reved it the weaker the signal to the ECU
Old 25-Jul-2006, 07:26
Mood: Saving
Yes mate it was the air pressure sensor that could only be diagnosed by plugging it into a pc .
Old 25-Jul-2006, 07:59
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
Nick - a long shot but check the loom plug going into the ECU is secure - my 748 displayed similar symptoms at Mallory last month and the plug into the loom had worked its way loose !
Nat
Old 25-Jul-2006, 09:55
NBs996's Avatar
Age, fuel breather seems fine.
Nat, there's no such thing as a bad idea - and so far wiggling a plug is the cheapest
Skids, stop saying expensive things! But you might be right - it's only happened when the motor gets hot chugging around slowly, tis ok once I get on the open roads and the temp drops a bit.
Think I'll have to hook it up to a diagnostic thingy and throw my credit card at it tho.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:25.
