Old 13-Sep-2006, 12:02   #21
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Anyone ever used MD Services for any type of servicing including suspension set up?
Old 13-Sep-2006, 15:31   #22
BDG BDG is offline
BDG's Avatar
Originally Posted by khushy
so what ARE your settings . . .
Front
compression (clicks out from fully in)
rebound (clicks out from fully in)
preload (turns from fully anit-clockwise)
and the same from the rear
Khushy
AT very best that would only give you a baseline and could be completely wrong. Can't imagine a 10 stone flyweight wanting the same settings as a 17 stone monster. OK i know he has posted his weight but whats suits one person may not suit another rider even of the same weight.
One of the things Colin at 100% Suspension do is ask for feed back during the course of the day and adjust as required.
Old 18-Sep-2006, 10:06   #23
BIG-G BIG-G is offline
BIG-G's Avatar
Mood: I started life with nothing and still have most of it left
Sorry been away.
Settings Front
Sag- 22mm (5 rings showing) Colin says 20-25mm needed
Comp- 8 from fully in
Rebound- 5 from fully in
Rear
Sag- 10mm (lift using rear footrests)
Comp- 3/4 turns from in
Rebound- 1/2 turns from in
Front now using loads more travel up to 4/5 on heavy breaking. More supple ride over bumps and no pogoing.
Old 18-Sep-2006, 10:23   #24
khushy khushy is offline
khushy's Avatar
Excellent job - now what are your settings?
weight
height
etc
Khushy
Old 18-Sep-2006, 18:26   #25
BIG-G's Avatar
Weight 16 stone
Height 4' 6'' ( I'm sitting down)
G
Old 18-Sep-2006, 18:29   #26
khushy's Avatar
LOL!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:37.
