Old 13-Oct-2006, 13:38
steve748kent steve748kent is offline
Question Brake light
Can anyone help me with a diagnosis,my brakelights fail to come on when using the front brake,but are fine in use with the rear brake.It can't be any of the fuses can it,only everything else seems to be working.Are there any hidden fuses or inacessable wiring ares where the problem may be ?
Old 13-Oct-2006, 13:52
Lily Lily is offline
Mood: stiff and tired
have you swapped to a different master cyl or such?
the brembo master cyl does not automatically have the connections into the loom.
Old 13-Oct-2006, 14:29
aka.eric aka.eric is offline
Brake light switch?
neil neil is offline
I'd suspect that the front brake microswitch (under the master cylinder) is sticking, give it a clean with some switch cleaner or WD40.......I've had an SS that did the same thing come MOT time!
Old 13-Oct-2006, 15:04
Loz's Avatar
Loz Loz is offline
Do 748s have bullet connectors between the leads off of the brake lever switch and the loom (as 749s/999s do)? If so, they may need a clean and some re-seating.
Old 13-Oct-2006, 20:01
Yep they do Loz, so they can always be pulled apart and the two ends from the main loom shorted together to check its not a break in the wiring in the harness.
If its the same problem as Brenda's (Mrs Everton to some) then it could well be a naff brake switch
Old 16-Oct-2006, 09:00
Duke2BSteve's Avatar
Duke2BSteve Duke2BSteve is offline
Yeah im having a similar problem, i've got a brembo radial master cylinder and with a small hand full the lights don't come on but with a large handful they come on, was told to look at the relay switch from the master cylinder? think i've located, its a couple of wires which attach at the bottom of the cylinder but can't see any obvious problems? any ideas?????????
Old 16-Oct-2006, 10:36
Nattyboy's Avatar
Nattyboy Nattyboy is offline
Mood: Back down to 3 :>(
Yes - stop using the brake you big wuss...!!!
Old 16-Oct-2006, 10:44
Harv748's Avatar
Harv748 Harv748 is offline
The wires you describe there are from the pressure switch, which the Radials have instead of a mech switch as such on the standard items.
Not sure there is anything you can do about it really?
Old 16-Oct-2006, 13:33
moto748 moto748 is offline
If you listen carefuilly (engine off, ignition on) you should be able to hear a "click" from the front brake microswitch. If you can't hear a click, the switch is misplaced/missing/broken.
They can become displaced. Mine has two tiny lugs which locate in two holes in the handlebar switch/master cylinder assembly, although I believe there are two different types. Pull the switch out, give it a squirt of WD 40, test that it works by pushing the button, and carefully reinstate it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:20.
