Old 14-Nov-2006, 15:35   #11
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Pic of bottle
Here's one I took earlier
Old 14-Nov-2006, 22:39   #12
jgriff jgriff is offline
jgriff's Avatar
Mood: anamorphic with overtones of sanguineness!
Now that is a mod! Tech points to you.
Griff
Old 15-Nov-2006, 09:37   #13
Jasper Jasper is offline
Jasper's Avatar
Doesn't all the coolant come out when you lean the bike over??
Old 15-Nov-2006, 15:06   #14
851neil 851neil is offline
Mood: need a bike...
mecks for a canny drinks bottle when yer a bit thorsty as well...
Old 15-Nov-2006, 15:24   #15
Rob B's Avatar
If you're worried about it leaking, use a RC boat/plane fuel tank with a brass "clunk" pick up. I've used these before and had no leakage problems. They have a breather tube/vent that you can take off an secure elsewhere.
You should only have an inch or so of expansion on the hottest of days, assuming your cooling system is in good shape.
rgds,
Rob
Old 17-Nov-2006, 06:39   #16
loony888 loony888 is offline
Mood: sensational!!
hmm, "the hottest of days".......where?
Old 17-Nov-2006, 19:55   #17
Mr.R Mr.R is offline
Mr.R's Avatar
Hi Rob, what's a "clunk" pick up? Does it work like a float valve?
Steve
Old 17-Nov-2006, 19:59   #18
Mr.R's Avatar
We get these in the U.K., between the wind,rain,snow............etc! You smug Git
Steve R. s.w.
Old 17-Nov-2006, 20:38   #19
Rob B's Avatar
Hottest off days was refering to odd days in mi July/August when the entusiasm/ability equation gets a little tweaked and yours truley used to sit in the holding paddock with a cooking engine, or getting red flagged part through a run and having to turn the car around in short order and do it all again. Water was never a problem with a well bled system and this system of expansion tank.
Steve,
Clunk refers to the weighted brass pick up (probably from the noise it makes) on a flexible tube that means it'll pick up the dregs of fluid, no matter where the G forces are pushing it in the tank.
Rgds,
Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:07.
