Old 20-Nov-2006, 20:09   #1
Albie Albie is offline
Albie's Avatar
Unhappy Bugger it snapped
Whilst trying to make my bike more cleaner I broke a bolt.
I was looking at the brake reservoir and it was corroded and flaking pretty bad so I thought take it of and wire brush and repaint. Rather than take off the windscreen I thought undo the aluminium allen shoulder bolt and then it will flex over to undo screws. Unfortunately it snapped on thread.
Has anybody got a spare bolt or bracket assembly as I will still have to drill out the snapped bottom.
Thanks
Andy
Old 20-Nov-2006, 20:14   #2
Dibble
Thanks
Andy
proof that cleaning is bad, I rest my case m'lud.
Old 21-Nov-2006, 13:33   #3
RickyX RickyX is offline
RickyX's Avatar
Those shoulder bolts all do that - dealer should therefore have a good supply of replacements.
I drilled out the remnants of thread from the captive nut. Make sure you install replacement bolt with grease/copaslip.
R
Old 21-Nov-2006, 20:40   #4
Albie's Avatar
Yes Dibble your right. I will have to pop into protwins again.Wouldnt have minded so much if the hex got mashed up.It maybe was too good a fit. Best leave it alone in future. Any ideas on aloose mirror apart from buying new ones. ????????
Old 21-Nov-2006, 20:55   #5
stu 748 stu 748 is offline
stu 748's Avatar
There is a small hole underneath the mirror you can put a slim screwdriver up inside and tighten the screw not too tight though, on the side of the back side of the mirror inside there is a plastic ball this fits into a socket and tightening the screw will tighten the mirror. if you tip the glass up and have a look inside you can see what i mean but just be carefull stu
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:01.
