Old 28-Nov-2006, 14:06
webbyc's Avatar
webbyc webbyc is offline
Mood: www.suzukisportingclub.com the only place to be
I found on my SPS that I had to have longer bars because they fouled the clocks which is an mot failure.
Old 28-Nov-2006, 21:09
khushy's Avatar
khushy khushy is offline
The brackets are . . .
Originally Posted by bradders
did you make the brakets or are they off the shelf? If I keep sps then I have a brembo to fit over the winter and will probably be looking for a clutch one too
thanks
bought - off the shelf - they are Motrax mirror bar-end mirror mounts that fit on the ends of the handlebars (I have long bars) I only used the bracket and the tapered internal bar mount - I then butchered the actual mirror mount - added a carbon rod - a titanium bolt etc and hey presto!
Khushy
Old 28-Nov-2006, 22:59
9rrr 9rrr is offline
Radial master cylinder
Just ordered some after market brembo master cylinders myself. Can you use the original brackets with the new cylinders ?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:28.
