Old 15-Dec-2006, 13:04   #11
paynep's Avatar
Mood: Wet wet wet
Originally Posted by multi600
Don,t know about the Sigma, one but the standard one is not worth fitting.
Mike
Mike, why do you say that?
Old 15-Dec-2006, 13:15   #12
rich-racing.co.uk rich-racing.co.uk is offline
rich-racing.co.uk's Avatar
Mood: make poverty history - cheaper Dukes now!
Ian Leah had a sigma slipper in his (my) bike last year. get in touch with the old man!
Old 15-Dec-2006, 13:19   #13
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
better than std clutch or std slipper that comes with the newer models.?
Old 15-Dec-2006, 13:29   #14
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
I thought the idea was that the slipper clutch stopped the back wheel from locking when down shiffting, I found the one (standard Ducati one) fitted to the Multi did not prevent this. Last year when I fitted the rear sets to the Multi I inadvetantly converted it to a race shift patern but did not realise till I was out on track, twice in the race at Castle Combe exiting corners I knocked it down a gear instead of up and the back wheel locked solid
Mike
Old 15-Dec-2006, 14:03   #15
paynep's Avatar
Mood: Wet wet wet
Mike
okaaay
Old 15-Dec-2006, 14:06   #16
fil2's Avatar
okaaay
Paul...
Wot slipper have u got fitted .?..the version that comes with the later models or an after market jobby.?
Old 15-Dec-2006, 15:01   #17
paynep's Avatar
Mood: Wet wet wet
One from a damaged S2R...........which is the same part # as the 620 one, and the one listed in the DP catalogue....
Likewise the 6-speed box, but I'm saving the heads and barrels until 2008 when I go play with the Sport 1000s... ;-)
Old 16-Dec-2006, 09:55   #18
the old man the old man is offline
the old man's Avatar
I ran Sigma slipper clutch in 2006 and can recommend it - I will be running a Sigma clutck in my Thunderbike next year.
Mine was a 5 speed 620SS. The standard clutch has a tendency to grab when coming off the line and I know others have had problems with clutch slip (mine was OK with an extra steel plate in the pack).
The Sigma slipper clutch cured all those problems; it gave smooth take up coming off the line; never slipped (once we'd got the correct spring combinations sorted) and made the bike much more stable on the brakes into the turns - I was a sceptic but ended a convert!
Old 16-Dec-2006, 10:01   #19
The clutck is a new Sigma development (was a secret till I just blabbed it now!!).
It is based on the standard Sigma device but incorporates some of the ideas Neil Spalding picked up in the MotoGP padocks - specifically it incorporated a set of sun and planet gears, causing the heavier clutch drum to rotate "backwards" emulating the Yamaha MotoGP engine (with its backward rotating crank) and - in theory at least - reducing engine gyroscopic effect.
Having the engine gyroscopic effects opposite to those of the wheels (both rotating forward - usually) reduces the overall gyroscopic effect fely by the chasis and makes the bike more nimble, improves traction and reduces the tendency to wheelie under power.
Old 16-Dec-2006, 11:35   #20
MLC Racing MLC Racing is offline
MLC Racing's Avatar
Mood: Moto Guzzi are the new Ducati??
Smile A lot of money can be a DANGEROUS THING
Slipper clutches eek! My old DLS bike with 58bhp, high bars, and std clutch came 2nd in 2005. Boggy's bike won 2005 without one. Is this not a case of over egging the pudding!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:25.
