Old 01-Jun-2003, 17:33
Jasper's Avatar
Jasper Jasper is offline
Bar risers/clip ons
As you may or may not have known,i was looking at selling my 853 due to a shoulder injury,i have now decided to keep her and TRY and adjust the riding position so i don't have to take painkillers all the time.What experience do you guys(and Gals) have of the different makes?LSL?GILLES?DP?HARRIS?All comments appreciated.Except from Old Yella,but he's always drunk anyway.And sulking.
Old 01-Jun-2003, 18:24
Felix Felix is offline
Or these?
http://cyclecat.com/home.htm
Lots of adjustment which is vital when you are trying to improve the riding ergonomics. Many of them are a fixed angle.
Old 01-Jun-2003, 20:19
Mood: aving a laff
Clip-ons
Met a guy today with the Gilles ones fitted which are multi adjustable but he did not have the risers.
Nice bit of kit to match the gold top yoke etc?
Clearance of the top fairing might be a problem but comments from people who have fitted em would help.
Nice enough comment eh ?
Sulk ?
Me ?
Not when I am drunk ?
Old 01-Jun-2003, 22:30
I think I saw the ad on E-bay - could hardly believe someone would sell such a stunning machine......
I've been looking at some for a while now, Helibars made in the USA are available here at:
http://www.custom-cruisers.co.uk/heli_bars/ducati.htm
they aint cheap however but......
Harris do a set of riser cip-on's that at least for an old 900ss I'm convinced will fit to the fork legs above the top yoke rather than below. Only for the brave though.
Good luck.
Old 01-Jun-2003, 22:51
Desmondo Desmondo is offline
Mood: :devil:
Didn't Totto have some risers at one stage. I'm sure I remember him selling some in Market Place. Maybe a quick U2U to him will help.
Old 02-Jun-2003, 03:44
Totto Totto is offline
Yep i did have a set ( Ducati Perf ) but sold them , as i moved the clip on's/levers & got the positon i was looking for without them !
But i did put them on & took them straight of again as i did not like the shape they put me in & they do not have any Adjustment cept up/down the fork legs , best try a set that are Fully adjustable .
Old 02-Jun-2003, 07:55
crm250's Avatar
crm250 crm250 is offline
Mood: Firing on all 4 !!
interesting thread this, as i suffer from the dead hand / numb 2 fingers after 25 mins on the 916, and anyway to lift the bars and bring them closer (without wheelying) would make this just a little comfier for me..
Old 02-Jun-2003, 11:20
Crm250 , do a search in the old Forum as this was covered quite a bit .
I like i said ealier I ended up moving the original clip on/lever's to suit me, it means removing a couple of pins but is well worth it as my 998 is now quite comfy !!!
I would recomend this to any one before
spending money on raisers , then if its still no good spend the money , I spent £160 on the DP bar raisers only to sell them a couple of months later at Half price !
Its a race bike , the racers would not just get on & ride , they would adj the bike to suit them !
I have some pics of the new bar position if you want a look !
Old 02-Jun-2003, 13:15
crm250's Avatar
Please totto, could you send it to
Cheers for you help
Old 02-Jun-2003, 15:50
Bar Risers
Sportbikes have a more forward riding position to purposely place the center of your body weight further towards the front wheel to better balance the bike and consequently improve handling. But for street riding it isn't the most comfortable position.
I installed Helibars on a 916 mainly to provide a more comfortable straight-up sitting position and to help solve a problem with numb fingers caused by handlebar vibration. However, after making this change I have mixed feelings about the new riding position. I prefer the previous handlebar position for more aggressive riding but I like the more comfortable neck position and my wrists don’t get as sore with the Helibars. Nevertheless, during certain riding conditions the angle of the bars just don’t feel right to me. I may change back or get a different product.
If I was to do it again I’d buy bar risers with some range of adjustment. The Helibars can be slid down the forks and rotated front-to-back but always keep their less-exteme tip down angle. I’d recommend instead a riser bar similar to that sold by Cycle Cat that are highly adjustable, but expensive.
I know that some riders have moved/modified their stock bars to raise the bar ends but this also sets the handlebars at an arbitrary downward angle that I find to be weird.
Numb Fingers Solution
Numb fingers when riding a motorcycle is a common problem. The fact of the matter is that when you apply engine vibration to the nerves in your hand, the nerves go tingly and fall asleep. The amount of vibration and frequency is different for different motorcycles and at different speeds.
If you ride a sportbike the problem is compounded by a riding position that puts more weight on your hands. The weight of your upper body transmitted through your hands to the grips causes compression of the palmer cutaneous branch of the median nerve. This nerve compression temporarily impedes peripheral nerve conduction, causing numbness. Further, the more weight you put on the grips the better the transfer of the vibration to your hands, also producing numbness.
The solution (in order of cost):
(1) Change your grip more often and loosen your grip somewhat. We grip the handlebars tightly in order to maintain the throttle position and our body position. Unfortunately the tighter the grip the better the transfer of the vibration to our hands. Since it’s harder to vary your throttle hand position you probably have noticed that this hand is most affected by numbness.
(2) Use foam grips ($5 grips from a bicycle shop work very well). You can lessen vibration by isolating yourself and/or the bars from the vibration source by positioning a cushion (low frequency spring) along the path of vibration (foam between your hands and the bars) and/or use something to isolate the bars (i.e. rubber mounts) or the engine (i.e. softer motor mounts) from the rest of the bike at high frequencies. You can also try new riding gloves with thicker leather or gel padding on the palms... every bit will help. Use different gloves if your fingertips touch the ends of your glove fingers while riding causing any vibration to get transmitted directly to the nerves in your fingers.
(3) Add weight to the handlebars - at the ends - LOTS of it. The handlebar is actually responding to the engine's vibrations and will vibrate in harmony (resonate) at certain engine RPM. You can change the resonant frequency of the handlebars so that the bars do not respond to the engine vibration at say cruising speeds (shorter stiffer bars will tend to cause the high amplitude vibration to shift to higher speeds, longer or weighted bars will tend to cause high amplitude vibration to shift to lower speeds). Some manufacturers include weighted bar-ends as part of the design.
Weighted bar-ends are added mass that will lower the resonant frequency of the bar so it vibrates less strongly but does not eliminate all vibration. In many cases, that's enough. You simply change the resonance to a frequency that the bike rarely generates or to a RPM that has less effect on the nerves in your hand. Shifting the resonant frequency is intended to reduce the strength (amplitude) of the vibration at your normal cruising RPM.
I went to a dive shop and paid £3.00 for a 3 lb. lead belt weight (wheel balance weights and lead shot mixed with epoxy would work too), cut it up, hammered it into shape and shoved/wedged it in the handlebar. It’s got to be in there tight to work, closer to the free-end works best. The lead piece in each of my handle bars is about 5 in X 1/2 in.
Those lighter dinky bar-ends and Barsnake things they sell in bike shops aren't going to help as much. Placing rubber caulk inside the handlebars as some have suggested is unlikely to have much of an effect (beyond added mass) in damping vibration.
(4) Install bar risers to provide a more straight up sitting position that takes your weight off your hands.
After adding foam grips, handlebar lead and Helibars, the numbness stopped for me altogether. Before these changes my throttle hand would go to sleep to the point I was afraid that I wouldn't be able to use my front brake in an emergency.
The problem is that our nerves are just in the wrong place for motorcycle riding. Darwinian evolution will solve this eventually. So, start with the foam grips and then the lead weights. In the meantime, while riding, get rid of the numbness more quickly by momentarily tapping your fingertips hard against your thigh to get the feeling back.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:16.
