General Motorcycles only
Old 13-Dec-2003, 15:22   #1
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Oil Filter Tool
Does anyone know where you can aquire the cup type filter tool that you drive with a 1/2" ratchet and that fits the Ducati size oil filters.
I have tried my local Halfords, bike shops and Demon Tweeks. Ducati seems to be a bit of an odd size at 76 mm and 9 flats.
Old 13-Dec-2003, 17:12   #2
the phantom pieman's Avatar
I spent ages looking , and ypu have three choices ;-
1) Halfords do a self adjusting thing that looks like a spider .....
2) The old stap thing , but you will get clearance problems
3) A screwdriver .......
Ducati employ apes on steriods to put on the filters ....
After trying various other methods 3) worked for me. I wish I hadn't wasted 4 hours before using the screwdriver ......
Old 13-Dec-2003, 17:32   #3
paulmort paulmort is offline
as pieman says
use 3/. its so bloody easy
oilbin under filter
screwdriver and mallet
tap, tap
oilcovered danny's but hey presto
the bloody thing rotates off
however for those that want more finess
Halfords now have a metalband type assy thats ultrathin so can go over body of filter
but no. 3 is always cheaper, quicker, easier
No doubt Nelly will call me a bodger, but it werks!!!!!!!
rgds
mort
Old 13-Dec-2003, 19:58   #4
Felix Felix is offline
I would caution you about the cup type. Usually the filters are on tight enough that those simply round off the edges on the filter. I have one, and it never worked. The strap type work well as already recommended. I've been down the screwdriver route as well and it once simply tore apart the casing. At that point you're down to the base and you need a tool to get the remainder off. I made a tool for that, as well.
Use the strap!
Old 22-Dec-2003, 19:02   #5
Nigel Booker's Avatar
You could always splash out and get the ducati oil filter wrench, if memory serves its about £16
Old 22-Dec-2003, 19:09   #6
Guido's Avatar
Failing that.......do the oil & filter changes yourself B4 each service and then you can be sure that King Kong didn't put the filter on in the first place.
Old 22-Dec-2003, 21:53   #7
I use a Sykes Picavant tool. It's a spring steel strap that is tightened around the filter, then use the whole tool as the lever.
The harder you push, the tighter it gets.
It's universal, and hasn't failed to shift a filter in over 15 years!!
They still make 'em to, I think.
an yes Paul..............ur a bodger
[Edited on 22-12-2003 by nelly]
Old 23-Dec-2003, 20:05   #8
no comment Neil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:21.
