Old 17-Jun-2006, 11:25
minty70uk minty70uk is offline
ECU Information
Can anyone tell me I own a 1995 916 Biposta, Does the 996 Biposta use the same ECU?
Old 22-Jun-2006, 13:34
RickyX's Avatar
RickyX RickyX is offline
If your 916BP has a 1.6M ECU - yes it should be the same but the chip is different.
I think only original 94 916 Strada had the P8 ECU (apart from the SP/SPS models).
RX
Old 22-Jun-2006, 14:45
Not the same.
ECU Models
Weber-Marelli IAW P7 ECU
851, 907 and early 888's up to serial number 000508.
P7s have no rear cylinder offset map.
Weber-Marelli IAW P8 ECU
Later 888's from serial number 000509, 916 Strada, 916SP, 916SPS, 996SPS
Note: The P7 and P8 ECUs turn-on the fuel pump once they initialize via a relay.
Weber-Marelli IAW 1.5M ECU
900ss, 750ss, Monster 900ie
Weber-Marelli IAW 1.6M ECU
One injector/cylinder: 748, 916 Biposto, 916 Senna, ST2
Weber-Marelli IAW 1.6M B1 ECU
Two injectors/cylinder: 996 Biposto, 996S
The IAW 1.6M uses a crank timing sensor at the cam jackshaft whereas the 1.6M B1 ECU takes it's timing firing points from the crankshaft.
Weber-Marelli IAW 5.9M ECU
2001 Monster S4, ST4S, 996R
2002 Monster S4, ST4S, Monster 620, Monster 900, 998, 998S, 998R
2003 Monster S4, S4R, ST4S, Monster 620, Monster 800, Monster 1000DS, 620S, 800SS, 1000DS, 749, 999, 998, 998S, 998R
Old 02-Jul-2006, 10:17
Hi everyone just to let you know the outcome of my 916 having been broken down for the past 2 months my local garage finally sourced a second ECU and guess what it still tripped the fuel relay after 10 seconds prompting an unplug to re-start. So that confirmed ECU was ok but we replaced the chip and bongo all is well it would appear in the last minutes of its life the rectifier decided to fry my eprom to bits. Now the question is do I leave the standard eprom in while running 45mm Termigonis or source a replacement? dealers says won't make much difference apart from maybe being lumpy at low speeds. What do you think? Also where is the best place to get one?
Old 02-Jul-2006, 11:09
wato39 wato39 is offline
Mood: Saving
Sorry if this sounds daft but , would the above be the same for all 748's including the R ?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:35.
