Old 30-May-2006, 20:13   #1
monstermob 998's Avatar
Unhappy Battery, rectifier or generator problem ???
just as i was thinking that i had got a reliable bike 600SS, the old girl lets me down.
historic symptoms;
rode the best part of 220 miles yesterday just bimbling around the southern counties bumped into skids and co at foxes last night all was fine - rode into work this morning just as i pulled up into the car park engine cut out pushed the starter and nothing no solonoid clicking no fairy lights on the dash and a very dim dipped beam pushed the horn button (no noise) and dipped beam degenerates into a non existent luminosity-- ah flat battery i thought, but why? i ask myself ,alternator,rectifier perhaps ah well i'll ring the AA later they'll have man that knows or at least i'll get the pleasure of a ride home in the recovery truck with the embarresment of well placed Ducati on the back--mid afternoon i decide to wiggle few wires in front of me workmates trying not scratch me head and makeing it look as if i knew what i was looking at and see if anything happens switched the key on pressed the starter and she fires into life ticksover well all lights etc bright as buttons- ah well wonder what that was all about then-- rode the bike home - well, within 50 yards of the front door anyway she cut out again same symptoms as before--
ive put the voltage tester across the ternimals theres only 8.5 volts
battery on charge now so i can get the engine fired up to test the rectifrier and genarotor output
so given the symptoms of a well drained battery this morning only to appear to have gained some mysterious added voltage thruout the day to start the bike and get me home tonight to break down with a discharged battery again-whats going on????? ive had no bulbs blowing or constant topping up of the battery - as if the rectifrier was doing its best to cook the battery-- i dont know the age of the battery altho looking at the cells in the battery they appear to be fine and also even if the bike has stood for a few days the starter has turned starter motor over very quickly-- the lights when the engine is running all appear to be fine so maybe the genorotor is working ok until the engine has cut out then like i said all the symptoms of a flat battery.
anyone had experience of similiar symptoms??? can any one shed ( excuse the pun) any light on the problem??? am taking bets on the cause but will know more as soon as the rectifier and genorotor is tested- oh and a new fuel filter was fitted two months ago - unless i got some real dirty fuel from somewhere
suggestions please?
dave
Old 30-May-2006, 20:24   #2
Harv748 Harv748 is offline
Harv748's Avatar
http://www.ducatisportingclub.com/sh...ad.php?t=29319
Some pointers to identify which component may be at fault.
Old 30-May-2006, 21:46   #3
I remember a mate having a similar problem years ago. he was traveling around with his headlight on dip and unkown to him the high beam filament broke away at one end and touched onto the low beam connection so he ended up trying to power 115 Watts of headlight, the bike wasn't designed for this so it flattened the battery. Turned it all off and after a while thge battery had recovered enough to allow the bike to start and was all OK until he turned the headlight on again. So it could be something similar and as you say the fule filter is worth checking in case its loading the pump excessively
Old 31-May-2006, 10:18   #4
phil_h phil_h is offline
phil_h's Avatar
Actually Dave, a similar problem stopped me on the ss at cadwell last year - it turned out to be the supply connections to the main power relay in the right of the front fairing. I would check the connections around there before spending any more dosh.
phil
Old 31-May-2006, 17:51   #5
havent spent any dosh yet phil--thanks for the tip-- still investigating and working thru the system - this may take some time as i dont really know the difference between an amp and an ohm-colour blindness doesnt help (have to seperate wires to get clear picture of the colours) and am a bit cheesed off at having to check all the connections that i replaced,cleaned and checked a few months ago-- but so far battery charged up to 12.56 volts - when engine is revved this figure does not change at all thru the rev range - so no current getting to battery-will be testing the regulator/rectifrier tonight
cheers
Old 01-Jun-2006, 07:05   #6
well everything is pointing in the direction of a faulty regulator/rectifier - not letting the current thru to charge the battery
BUT last night when i initially switched the ignition on, the red charging light came on as did the other fairy lights then immediately fell away to a non existent glow,before i hit the starter button the other lights remained on- hit the starter button 'the bike fired up the charging light remained extinguished-switched off the bike and the charging light remained off for the rest of the testing by this time i thought that the bulb had blown eventually stripped all the dash apart to find that the bulb was in fact ok- why doesnt the bulb light up when the the ignition is switched on? if the circuit is not charging the battery why doesnt the light tell me its not working? or have as usual misinterpereted the meaning "charging light" or does it light only come on when there is a total charging loss from the genarotor ,which i dont understand cos the warning light is is wired in after the current has been thru the regulator /rectifier- when by this time you would know about it any way?
as you can tell auto electrics is not my strong point(still searching for one of those )
phil -the general relay clicks on/off fine
going to pick up a new regulator later bet its not a straight forward plug and play job
Old 01-Jun-2006, 19:47   #7
HELP!!!!! got replacement from ducati but it is different the wires are different colours i have now two yellows two greens and two red/white coming from the unit i guess the two yellows connect to the existing two yellows from generator
the two greens connect to the existing red/white and red/black and the two reds connect into the single red black and not forgetting to bolt on the earth is this right?
Old 03-Jun-2006, 13:08   #8
well thru trial and error i fitted the new unit
bike starts ok ticks over ok current goes into battry rev the engine to get better reading and the 15 amp fuse blows to fuel pump and ignition indicating a short circuit inspect all wires replace fuse bike starts ok ticks over ok current goes into battry rev the engine to get better reading and the 15 amp fuse blows replace fuse bike starts ok ticks over ok current goes into battry rev the engine to get better reading and the 15 amp fuse blows
then i notice that when fuse replaced ignition on charging light does not illuminate bike starts ok ticks over ok current goes into battry rev the engine to get better reading and the 15 amp fuse blows charging light illuminates
swop back over regulator unit to old one recharge battery switch on, charging light illuminates, goes out when engine running but alas no charge going into battery after several more switches on and off and more multi meter testing more revving of the engine as well as turning into contortionist to hold multi meter points at the strategic points to test as welll as controlling the throttle all this in my fully air conditioned scenic workshop in full view of my well pi**ed off neighbours
in short the thing aint working and ive lost me patience ---see you all later
Old 03-Jun-2006, 13:20   #9
total nightmare Dave, almost seems as though you have multiple faults.
I hate electrics too.
I wonder if you have got a later model regulator; not sure what year model yours is - I've just fitted an electrex reg. to mine after the original gave up the ghost.
Blowing 15A fuses sounds major to me and I'd of stopped after the 2nd one blew. Time for some professional help I think - electrical in this case.
There is some thing weird that sticks in my mind for some reason - I used to have a 1979 BMWR100Rs and if the charge system warning light bulb blew, it stopped the charge getting to the battery! I used to carry a spare with me. However, you have see a charge getting to the battery - so this isnt the case.
Good luck mate - take a break from it.
Old 03-Jun-2006, 16:00   #10
A DC fuel pump trying to overcome a plugged fuel filter or crimped fuel line can easily draw 15 amps - one of the prime causes of regulator failures. The charging system can't put out the 15 amps at idle so it makes sense that the fuse blows when you rev it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:21.
