Old 23-Jan-2006, 18:08   #11
Ducnow Ducnow is offline
Originally posted by electricsheep
it is because the 749R has a different primary drive ratio, therefore it needs a different final drice ratio (chain and sprockets)
Did you changed the front sprocket in "our" 749R ?
Old 23-Jan-2006, 21:41   #12
Mood: Diet
you'll have to count the teeth
Old 23-Jan-2006, 21:46   #13
Twinfan Twinfan is offline
Twinfan's Avatar
Sorry, but if you want a closer gearing shouldn't you go a tooth less on the front or add more teeth to the rear???
And that would mean that 15/35 is wayyyyyyyyyyy taller than 14/38, right??
I mean, if it was 14/35 vs 15/38, then it would be more balanced, right???
Oops - sorry, my mistake. I was thinking one cancelled the other out on the 749R but it obviously doesn't. It's "two steps" longer than the regular 749.
15/35 is similar to 14/32
14/38 is similar to 15/41
Old 23-Jan-2006, 21:49   #14
Carbon749's Avatar
Mood: I own a flame thrower
After all this, I think I'm in the market for a 14 tooth front sprocket
Old 23-Jan-2006, 22:46   #15
Mood: Diet
quatorze
Old 23-Jan-2006, 22:50   #16
quatorze
Obrigado
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:41.
