Old 25-Jan-2004, 17:00   #1
Dave G Dave G is offline
Dave G's Avatar
Non starter
Just tried to fire up the bikes after sitting in my garage for a month-unused and unloved.
The 916 started first time off the button as it always has(forgot how loud it was),the ss was a different matter though,the starter turns and the odd backfire told me that fuel is getting through,it even grumbled a bit as though it was about to start but came to nothing,I tried with and without choke.
I cant believe its the petrol after only a month, the other bikes started without too much effort.
Anyone have any ideas what to do next? or had the same problem,the spark plugs are new but I might as well check them next.
D.
Old 27-Jan-2004, 06:28   #2
What model is it?
If it is a carbed model they are notoriously dificult to start in cold weather.
Old 27-Jan-2004, 08:24   #3
Could be petrol after just a month. If there wasn't a lot in the tank to start with it would have lots of air to help it go stale. I've got a Montessa trials bike that's carbed and it doesn't like starting on petrol that age. It's a pretty crude old nail with magneto ignition so it's a marginal starter in cold weather anyway (just like the SS's according to Keefyboy) so it might not take much to be the straw that broke the camels back.
Old 27-Jan-2004, 09:45   #4
Dave G's Avatar
Its a carbed 97 model,strangely, knowing they are difficult to start in the cold almost reassures me its not too serious a problem
Also had a look inside the tank,from the odometer I'd say Ive done 40 miles out of a full tank,the fuel level just covers the pipe visible beneath the cap.
Is there anything I can do(other than to drain all the fuel-something I've never had to do),perhaps an additive to the petrol to kick start it,basically something that a techno-moron like me could easily do to help get it going.
If a month is too long I'll take this as a lesson and turn it over more often.
Old 27-Jan-2004, 13:49   #5
Derek Derek is offline
Bikes: ST4s ABS
Derek's Avatar
It's possible that the fuel remaining in the float bowls evaporated and left a gum which is blocking the pilot or starter jets. Unleaded is very bad for this apparently.
I always drain the float bowls when I lay the bike up for the winter just in case.
Old 27-Jan-2004, 17:57   #6
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
fuel has a shelf life of 6 weeks after which it will gum up your injectors/carbs (delete as needed)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:34.
