Old 03-Jun-2003, 20:49
Ian's Avatar
Ian Ian is offline
Mood: Still having fun!
popped into Halfords after work for the 46 and 41mm sockets myself. Oh no we will have to order them for you, - prices £56 and £46 !!!!!!!!!!! Are you sure ? No sir, there may be alternatives but it is too close to closingtime you will have to come back tomorrow. Maybe I won't bother.
Old 04-Jun-2003, 04:55
Totto Totto is offline
Got some imperial (46mm) eqivalent sockets , turned down to suit the narrow wheel nut !
Half inch drive !!
£15 delivered
[Edited on 4-6-2003 by Totto]
Old 06-Jun-2003, 10:18
rcgbob44's Avatar
rcgbob44 rcgbob44 is offline
Hugger
I picked up a 3/4 inch drive socket from the Ally Pally Show for £5.00 and a 3/4 to 1/2 inch adaptor for £4.00 and there ok, I would suggest that if you want to do the job properly then you remove the wheel, tap the swinging arm and do not forget to torque the wheel nut correctly, All torque settings can be found on the Ducati.Com site. Good Luck
Old 06-Jun-2003, 14:13
Ian's Avatar
Ian Ian is offline
torque settings
i gave up with the do it myself job, - and took the bike into a tyre fitters this morning, - my Ducati dealers were booked in with other stuff for weeks. The tyre place was Watling tyres in South Croydon and credit to the guy who did it,- he was very careful with my wheel.
But on putting the wheel back he said that they never torque set the wheels, - the drill they use does them up tight enough, - but how did he know how tight it was? I did n't make a fuss (how English) as to be fair the guy was doing a very careful job, and i was being a pain watching his every move.
But, does anybody else know how tight these guns do up? I guess i know that i should take it back to the Ducati dealer and get it checked but I now feel a bit guilty as i went elsewhere (if you know what I mean).
Old 06-Jun-2003, 17:51
maddott maddott is offline
Mood: affmanut
The imperial one I got from Halfords is 1" and 13/16, and it's black, like an impact socket
Old 07-Jun-2003, 17:48
rcgbob44's Avatar
Rear Wheel Torque Settings
I hope this helps:
Rear wheel nut should be torqued to 176 Nm, this equates to 129.8 ft lb`s. I have attached the ducati tech spec sheets detailing this, if you need to convert the other settings you can get the conversion bits from the web. Good luck
Old 08-Jun-2003, 10:24
Ian's Avatar
Ian Ian is offline
thanks, - i took it to P&H yesterday afternoon, - and they undid it, checked it, torqued it, and charged me nothing. Thanks P&H. - My mate bought a new ZX7R, - a good looking bike with some real racing history, - for a rice burner.
  #18
Old 08-Jun-2003, 17:52
Rear Wheel Removal
You'll need a six-point 46 mm (1-13/16-inch) socket and a torque wrench with a handle extension. Most sockets this size are 3/4-inch drives so you also may need a 3/4-to-1/2-inch drive adapter.
Check your socket construction. You may need to machine down the hex end of the socket if it has recessed flats. Otherwise, you'll only get partial engagement of the socket flats on the comparatively thin nut. There's high torque involved here so you'll want to anticipate slipping and damaging the nut.
The rear wheel is held on with a 46 mm nut cross-drilled to accept a safety retaining clip that is installed as a safety precaution to prevent the loss of the nut. If the nut was not torqued correctly when last installed, the nut may have loosened a bit and captured the pin. This will prevent the socket from being placed over the nut, so you may have to cut off or pry the pin out.
You can expect that the rear wheel retaining nut will be VERY difficult to remove, usually requiring the use of an impact driver (or a long handle extension) to get it off. Over time it seems to get tighter.
The best way to keep the wheel from turning while removing the nut is to have a helper apply the rear brake lever with a normal amount of force. Be careful, too much force on the lever can break the rear master cylinder bracket which is the pivot point for the rear brake pedal.
Rear Wheel Installation
A Ducati tech bulletin and their web site specifies 176 Nm ± 5% torque requirement for the rear wheel retaining nut (normal thread direction). This converts to 124-137 lb-ft.
Applying an anti-seize lube to the threads will help to assure an accurate torque reading and make it easier to get the nut off later. The manual calls for Shell Retinax HDX2, an automotive grease.
When reinstalling, first make sure that the wheel is seated properly. Mount the wheel and tighten the nut to about 50 lb-ft. Then rotate the wheel and pound the side of the tire with the heel of your hand in several places around the circumference to seat it. Then tighten to about 80 lb-ft and repeat, applying the rear brake lever to keep the wheel from turning. Finally, tighten the nut to 124 lb-ft and check the retaining pin hole alignment. Torque again as high as 137 lb-ft to line-up the holes and insert the retaining pin.
If the nut is under-torqued it will allow the nut to loosen, allowing the wheel to rotate in its mount and be damaged by repeated acceleration/braking impact loads that will ovalize the four locating pins holes on the backside of the wheel. Damage to the axle spindle can also occur. Also a loose nut will back-off till it's stopped by the retaining pin, then bend the pin and deform the nut. It's a good idea to mark the nut position with a marking pen, so that you can quickly see if the wheel has moved after a ride.
During installation, you should never loosen the nut to insert the pin. The range of correct torque values for the nut is 124-137 lb-ft so the correct procedure is to torque to the lower value, check for hole alignment and torque up to the higher value if necessary to align the holes.
Note that if you are installing aftermarket wheels, a small variation in wheel/paint thickness may make it more difficult to apply both the correct torque and also get the correct hole alignment.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:15.
