Old 12-Feb-2004, 14:39
ben998 ben998 is offline
Oil mesh filter?
I remember reading about a mesh filter that is in addition to the normal oil filter. Could someone advise me where it is, and how I remove it for inspection. I seem to remember that its a good thing to inspect when looking for bits of chrome off the rockers? (not that I have a problem, just going to do an oil change)
Old 12-Feb-2004, 14:59
DJ Tera DJ Tera is offline
Ok, its on the right side of the engine near the bottom of the casing, its a HUGE hex socket type affair, you cant miss it
Old 12-Feb-2004, 15:09
Thanks DJTerra - Right side being foot brake side and the huge hex socket underneath the oil sight glass window?
Old 12-Feb-2004, 19:34
Yep, good luck finding an allen key big enough - seems ducati decided to change the size for the testastretta models
Old 13-Feb-2004, 07:29
Looks huge! Id be better off welding a 50p piece onto a piece of bar and using that.
Old 13-Feb-2004, 19:32
Bianchi Bianchi is offline
Its 14mm and use a wrench with a long handle, it will snap free so watch your hands. Same goes for the inner oil mesh filter. That's a long mesh tubular type affair, again using same 14mm head.
After inspection and cleaning put the lot back together using a short arm wrench. Have heard of people applying too much torque and stripping alloy threads. Veeery expensive.....
Good luck.
ps this is on a 2001 996
[Edited on 13-2-2004 by Bianchi]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:23.
