Old 22-Feb-2004, 18:18
Rick_916 Rick_916 is offline
Mood: FREEEZZZING
Water coolant
Hi
Me again
I am curious about how you know the right coolant level, and how if I need to fill it up do I go about it. I am asking alot as before I just sent the bike to the shop to get anything done but now I am in Sweden and it costs so much , also I think it is fun now to learn as much and do as much as I can BUT I NEED ALOT OF HELP.
Old 22-Feb-2004, 19:49
Dibble
Rick,
If you look at the front of than on clutch lever side you will see a white bottle near the headstock under the ignition key, thats water \ coolant bottle, on the side of the bottle are minimum and maximum markers for the levels.
The lid is on the top but a bit obscured by the tank and if it hasnt been opened for a while you may need to lift the tank out of the way to get a proper grip ...
If I can do it .. anyone can ...
Hope that helps mate ...
Old 23-Feb-2004, 08:00
ben998 ben998 is offline
I was going to ask a similar question.. do you check the level in the coolant reservoir when the bike is on its side stand and therefore leant over in the direction of the min/max levels on the side of the reservoir, or when the bike is off the stand and vertical?
cheers,
Ben
Old 23-Feb-2004, 09:55
ziggi's Avatar
ziggi ziggi is offline
vertical, both wheels on floor.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:55.
