Old 02-Mar-2004, 21:30
Chef's Avatar
Chef Chef is offline
Bikes: 998S Chili trackbike,749R (corse kit), 748SPS
Mood: Flange - it's a state of mind....
Downchange problem
Took my bike out for a pre Almeria spin to check it was all fine and............found that occasionally when changing down the gears would be solid - ie wouldn't change down at all. Seemed to be only on downchanges - weird - never had it before and have no idea what might cause it - only done 200 since it was serviced, but that was a few months ago (shame on me!). Felt like the clutch wasn't engaging?
Any suggestions??????
Old 02-Mar-2004, 21:36
madmav's Avatar
madmav madmav is offline
Bikes: 1098
Mood: Chilled
Hi chris !
i had this after bike had stood ! after checking the usual it turned out to be a De-tent sping !!!!!!!!!
easly sorted speak to nelly . regards mav
Old 03-Mar-2004, 08:14
Michael J Michael J is offline
This sounds vaguely familiar As JHP told me "Stamp on it"! Should work fine then!!
Old 03-Mar-2004, 22:05
Chef's Avatar
Thanks for the advice
What is a De tent spring & where does it live??
I have the technical knowledge of a potatoe.....
Chef's Avatar
Old 03-Mar-2004, 22:28
try under the big nut on the back of the crank cases, LHS just above the swing arm pivot.
Also check gear linkage rod end bearings as they can go stiff and cause problems, also if the gearchange arm isn't in the correct position on the spline it can have problems but this is usually associated with up changes
Old 04-Mar-2004, 11:09
Check your clutch, take the pressure plate off and see if the HUGE nut that holds the clutch drum in place is tight.
You haven't got a slipper in there have you?
Old 04-Mar-2004, 22:40
Chef's Avatar
Thanks for all the info
JP - no slipper, a jhp lightweight clutch which has been good (my second) - better than oe ones that's for sure!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:33.
