Old 07-Jun-2003, 03:03   #1
scooter996 scooter996 is offline
fuel in oil?
I have a 2000 996 with 4200 miles on it. I usually do oil sampling to make sure that all things are going okay. Well the last sample that I sent in was a bad one. I got a call from the lab that runs the samples late last night. She said that there was excessive-critical-unacceptable amounts of FUEL in the oil sample :WTF: . Anyone else test there old oil and have the same problem or anyone found fuel in there oil? I do have the extended and Ducati regular warranty but I can hear them now saying that they wont pay for any repair until the bike breaks down. I would like to FIX the problem before it gets worse! I dont think DNA believe in PREVENTIVE warranty work. What should I do? Help please
Old 12-Jun-2003, 20:49   #2
kfz kfz is offline
oh dear this is very bad. Where are you up to?
Old 13-Jun-2003, 18:51   #3
LukeDuke LukeDuke is offline
get the cylinder head compression tested to see if your piston rings / barrel are excessively worn ?
Old 15-Jun-2003, 20:36   #4
kfz2 kfz2 is offline
Sorry guys i think your all going the wrong way with this.
If theres a large amount of unburnt gas in the oil, then the chances are its comming out of the fuel tap while the bike is parked up (yes i know the over flow should drop it out).
I suggest as a matter of caution that you chekc the tap is not running while the bike is stopped (its a vaucumn tap right?) and that both the varbs overflows and vents are clear.
You know this is extremly bad and fatal for any engine.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:17.
