Old 09-Apr-2004, 20:17   #11
Billythekid Billythekid is offline
Mood: indifferent
Where is the main earth on the chassis? its certainly a good idea, I know a bad earth on a car can cause havock!!
It almost seems heat related as well,
runs fine for 5 mins, tacho goes
30 secs later bike stops.
wont even turn over once stopped, neutral light barely illuminates.
But leave it for over 30 mins and itds fine again, bach to step one?!
Odd
A pretty miffed Joel
Old 09-Apr-2004, 21:11   #12
neil748r neil748r is offline
Have you checked all the battery and regulator/rectifier wiring? Really prone to melting and breaking down especially the yellow wires that come across the bike from the stator. Iv'e seen bikes displaying all the symptoms you desribe and when the wiring was checked, all the connectors were melted and the insulation from the yellow wires was completely gone for about 4 or 5 inches back from the connectors!
Am I stating the obvious?
Old 09-Apr-2004, 22:07   #13
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
The main battery to earth connection is not on the frame, it's on the crankcase - look at about 11 o'clock on the clutch cover,go in about aninch past the cover & slightly above the swing arm pivot & you'll see a button headed allen bolt holding the earth lead on. They can be a total barsteward to remove.
I've got some new battery leads for mine & have got to take the old ones off..... not looking forward to that!
Old 10-Apr-2004, 01:04   #14
Mood: indifferent
Ive had a quick look at those yellow wires and they seemed ok, not followed them the whole way back mind. Also the alternator stator is only about 500 miles old, whether its duff?!
Managed to borrow a multi meter and a bm80 at last too so ill have a decent examination tomorrow.
I'll let you know of progress,
Joel
Old 10-Apr-2004, 12:09   #15
Mood: me in a mood? NEVER!
good luck
Old 10-Apr-2004, 14:07   #16
There must also be an earth connection from the engine to the frame?
Old 10-Apr-2004, 21:05   #17
Mstt Mstt is offline
Mood: Kool as ice...
Had a simular problem fairly recently,
yes it was the wiring that had burnt through.
Before i knew what the problem was i recharged the battery and the bike ran for a while, had all the wiring checked out and the problem was found, happy hunting!
Old 10-Apr-2004, 23:07   #18
rcgbob44's Avatar
My Puch Maxi was always reliable!
Old 10-Apr-2004, 23:45   #19
bostrom998 bostrom998 is offline
bostrom998's Avatar
Mood: Long on Duke's...so happy
My SEnna used to do that, including a very embarrassing lap at the Nurburgring riders club where we were all meant to keepo lights on when at front or rear and the instructors used to go psycho if you didn't have light on. Sitaution got so bad I had to turn lights off at Bergwerk ('bout half way round) and even when I applied brake light it would splutter. (you ever tried to go round 'ring withOUT braking?) In the end it was a loose connection between alternator and regulator somewhere, so it's always worth checking all connections I reckon.
Old 11-Apr-2004, 02:35   #20
Mood: indifferent
Checked all wiring, its all spot on.
Resistanse accross the stator is as it should be acordig to haynes.
But AC voltage is about 1/2 - 2/3 what it should be att all revs acording to haynes.
With ign off batt ha 12.8V accross terminals, running its bout 11.5-11.8V, so my guess is alternator stator, must have shorted a few windings somewhere!
All earths and cable continuities spot on,
I have now had enough, I need some persuation not to go to Honda!!!
Joel
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:25.
