Old 13-Apr-2004, 21:58   #11
everton
Not sure what you mean by pilot hole, Everton cos we're talking about the standard Ducati fitting being drilled aren't we? Why would there be a pilot hole?
You're right..............you do have to drill out the standard Ducati fitting..........but there was a pilot hole already on mine and all I had to do was drill it out slightly.
Hope to get some pics up tomorrow.
Old 14-Apr-2004, 15:51   #12
everton
Here's a couple of pictures as promised.............
Old 14-Apr-2004, 15:52   #13
everton
Close up of the drilled & fitted light.............
Old 14-Apr-2004, 16:24   #14
robracenut robracenut is offline
Thanks for the pics m8 -- looks a very neat job. Definitely a big improvement over all the girderwork on the original!
Rob
Old 14-Apr-2004, 16:27   #15
Ned Ned is offline
Does look great Everton!
But can't see if you included a reflector. These are MOT-required.
"Statutory reflectors
Mopeds and motor bicycles require one unobscured red reflector which is aligned to the vehicles longitudinal centre line and is positioned to reflect squarely to the rear. "
There should be another place we could fix it, I guess...
Ned
[Edited on 14-4-2004 by Ned]
Old 14-Apr-2004, 16:37   #16
everton
Ned,
Yes I did keep the reflector and it is just bolted to the bottom the number plate although the picture doesn't show it.
Old 14-Apr-2004, 16:45   #17
Ned Ned is offline
Cheers Everton. I'm going to use your pics as my Haynes manual on this one!
I ordered mine from Cornerspeed yesterday. First time I've dealt with them, but I was very impressed. They guy there didn't want to sell me any bits for the 749 that he couldn't personally vouch for the quality of. Instant trust factor = 10
Ned
Old 14-Apr-2004, 17:16   #18
Sorry Everton -- another question. Re. the reflector, did you use the one from the standard tail light kit and can it be unbolted? Or can you just cannibalize a Halfords bicycle reflector kit maybe?
Sounding a bit more complicated now..
Rob
Old 14-Apr-2004, 21:50   #19
everton
Rob,
The reflector is the original one from the original 999 plate hanger unit. It is a separate piece bolted through the hanger and the plate.
With the Casoli hanger on the reflector is simply bolted to the plate itself now.
Old 17-Apr-2004, 23:50   #20
Ned Ned is offline
All fitted now. Not hard at all, although the instructions (Evoluzione) did differ a bit from the layout of brackets/nuts etc on my new 749. Also a couple of fairly obvious things were missed out - but all pretty easy in the end.
Now looks much tidier, even with the reflector bolted onto the bottom of the plate.
Ned
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:31.
