Old 17-Apr-2004, 19:50   #11
you know my syringe method makes sense.... look for an old thread with old yella, itll work.
Dont pss about taking anything off the bike, its only air!!!
Old 17-Apr-2004, 19:56   #12
DJ Tera DJ Tera is offline
Andy your way seems the easiest, have to wait til the chemist opens, or I could just go to the local council estate...
Oh, you said NO needle
2 of the bolts holding the slave cylinder on have gone walkies too, bloody vibey twins!
Old 17-Apr-2004, 20:01   #13
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
dj just trying to help ! its easier to do than explain ! sorry if it looked confusing! regards mav
Old 17-Apr-2004, 20:25   #14
Nigel C Nigel C is offline
Nigel C's Avatar
Mood: happy bike passed MOT
bleed nipples
these may be of help !!! they do next day postage as well
Old 17-Apr-2004, 20:27   #15
mav wasn't having a dig mate, was just wondering how to get the fluid out of the bottle and in to a tube or pipe!
Old 17-Apr-2004, 20:29   #16
Bikes: 1098
madmav's Avatar
Mood: Chilled
no probs dj ! u are a bit to far 4 me to cum sort it 4 ya! so hope all goes well 4 ya 2 moz! mav
Old 17-Apr-2004, 20:36   #17
Mood: me in a mood? NEVER!
what a little confusing you have said you have left the piston behind and you will need it in place or it will just run out and get air in.
Old 17-Apr-2004, 20:38   #18
Ricky-X Ricky-X is offline
DJ,
I had EXACTLY the same problem last year..tried the syringe, took the slave apart, clamped the piston...all to no avail...
What finally worked was: undo the handlebar clamp, tilt the lever/master cylinder assembly upwards so that air can rise from the banjo bolt (at handlebar end) and into the master cylinder. Hey presto..little bubbles of air come skipping merrily into the master cylinder and the lever pressure miraculously returns!
Give it a whirl..it takes about 5 mins.
Good luck.
Old 17-Apr-2004, 20:45   #19
The easiest way is to install a bleeder fitting up at the clutch master cylinder since any air bubbles in the system will rise to the highest point. Why Ducati put the bleed valve at the system low point I’ll never understand.
If you can't find one, you can try just loosening the bolt slightly and bleed air from the banjo bolt as if it were a bleeder fitting.
Be careful to avoid spraying the hydraulic fluid. Keep plenty of rags handy to clean up any spills and cover everything. The fluid is corrosive and will damage painted surfaces and certain plastics.
Old 17-Apr-2004, 22:24   #20
mike916 mike916 is offline
Mood: Neutral - but only maybe. 1994 Duc 916S1, 2006 Duc Sportclassic 1000 Sport
I cant believe that photo - clear fluid - mine only stays like that for about a week and that with a new slave piston, Goodrich hose and DoT 5 fluid!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:14.
