Old 15-Apr-2004, 22:13   #11
Harry S Harry S is offline
Harry S's Avatar
Dukes, 748, 998 & 999s, are notoriously shy to get wear right over to the edge of the standard fitment tyre I believe, especially if you've been used to riding another make of bike..... That'll be the non-technical answer within this thread then...
H
Old 16-Apr-2004, 09:07   #12
bazzer sps bazzer sps is offline
Roy,
Thanks for that,but have you a 180 or 190 on the rear?
Thanks
Old 16-Apr-2004, 14:42   #13
duc749s duc749s is offline
Again, totally non-technical but...
I changed to a 180 on my 916 and didn't really notice any improvement.
On the 749 i've stuck with the 190 and not had a problem using the whole of the tyre...
Probably just a case of getting used to a different type of bike.
But hey, each to their own - try it, you might like it! What's the worst that can happen?
Old 16-Apr-2004, 16:22   #14
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
Originally posted by bazzer sps
Roy,
Thanks
Sorry Bazzer 190, can't seem to get rid of the little chicken strip (no problem on the Mich), but hey, probably just cos I'm a slow old git
Old 17-Apr-2004, 16:22   #15
Harry S's Avatar
I had a190 on my 998 and manged to get rid of the chicken strip, bar about 2mm.. grazed my elbow doing it...
Old 17-Apr-2004, 18:10   #16
Thanks for all your replies but i would like to hear from someone that has actually changed from a 190 to 180 and wether the change was noticeable.I know when i changed the sps rear tyre to a 180 the difference was very noticeable but that was a common mod most 9** owners made.
I have to say the 999 steers much faster than the sps with the 190 on and assume it would be even quicker with a 180.
Old 19-Apr-2004, 10:59   #17
dickieducati's Avatar
will be changing to a 180 in the next week or so. first time out will most likely be on track at cadwell either the dsc day or maybe the weekend before. running diablo corsa at the minute, changing to supercorsa's. get pretty much right to the edge of the 190's. looking for quicker turn in and maybe increased corner stability
Old 23-Apr-2004, 22:59   #18
KeefyB,
Did you stick the 180 on and if so how did it feel?I rang Ducati Uk and discussed the issue of tyre size and he said "The 999 was designed to run with a 190 tyre and felt there would be little benifit in changing to a 180".So i'm not sure what to put on now.Also has anyone got experience of Bridgestone 010's on a 999,i need a durable tyre as i'm riding down for WDW.comments aprreciated.
Hmm,the 749 has the same rear rim and has a 180 fitted as standard.Why?
Went out for a gentle blast tonight to scrub in the RR's.First impressions were that the bike felt a little nervous.That could have been down to me tho.(Remember the "Bad Friday" post?)
After a few gentle miles to warm the tyres up I started to lean the bike a bit more.The bike does seem to turn in a bit quicker and is very stable mid corner.I did about 70 miles this evening and the tyres are scrubbing in nicely.Well happy.
Old 25-Apr-2004, 11:27   #19
hk999 hk999 is offline
i am looking to change the rear to 180 next, having read the +ve comments here.
Old 27-Apr-2004, 07:49   #20
jk2 jk2 is offline
jk2's Avatar
Worth remembering you will get a larger contact patch with a 190 section tyre when the bike is cranked over. If you want the bike to steer quicker, try raising the rear ride height adjuster.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
