Old 16-Jan-2009, 11:46   #111
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Originally Posted by Senna3
i recon miss riot weighs about 7 stone so she should have to wear a five stone lead belt to equal my weight as for dom he will have to cut one of his legs off
How do you think I feel? I weighed in at about 22 stone in my leathers!
Old 16-Jan-2009, 11:53   #112
MARTIN H's Avatar
Originally Posted by ChrisBushell
Now about 20 years ago when I last had my Jaguar engine apart, I had the whole crankshaft assembly (from front damper through to the clutch pressure plate) dynamically balanced. The engine was subsequently significantly smoother and appeared to spin up easier. This is on a 6 cylinder 3.5 litre long stroke engine!
Chris, can you recommend anywhere to supply/remake an XK crank damper? Got a 3.8 engine here that I'm building (very slowly) and 3 dampers (all in poor condition) off various engines.
Old 16-Jan-2009, 14:46   #113
I should think you feel Very Heavy
I'm certainly not going to try and lift you off the ground
And thankfully when you were on the Multi you never toppled over onto me I would have been squashed
Old 16-Jan-2009, 16:25   #114
only 22st.....
Old 16-Jan-2009, 17:09   #115
MARTIN H's Avatar
Originally Posted by bradders
only 22st.....
Yup I've been dieting
Old 16-Jan-2009, 17:54   #116
so have I - unfortunely the classic see-food one!!
Old 16-Jan-2009, 19:07   #117
MARTIN H's Avatar
I think we should petition for a Class C in DD - for the fully grown gentleman.
Old 16-Jan-2009, 19:13   #118
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
How about a combined rider and bike minimum weight limit of 250kgs?
Old 16-Jan-2009, 19:25   #119
Fastfasulli Fastfasulli is offline
How about ditching qualifying and replace it with a practice instead. Then chose the grid randomly.....that could be....fun... I think the MZ's do this in Bemsee
Old 16-Jan-2009, 19:51   #120
At Darley Moor you used to pick a number out of a bag whilst in the assembly area, a right pot luck.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:27.
