Old 25-Mar-2009, 16:20   #11
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I used the BSI weights at work to check them and carry out a direct comparison with one of the sets of calibrated scales at work, which are checked not by lloyds but E.H.Oakley to UKAS standards, which I have to make sure gets done as one of my roles is the Calibrated Equipment officer responsible for maintaining a calibrated equipment register that is Audited several times a year by the likes of the BSI and the FDA.
Thought you would have that coverd Kev, can you get our bathroom ones checked my misses recons they weigh at least 5lbs heavy
Old 25-Mar-2009, 16:29   #12
Thats what I thought about my Kern ones when I got them and weighed myself, sadly the bu99ers don't lie, they are very accurate less than 1% error over the range tested.
Mind you they do cost a bit more than your average bathroom scales
http://www.kern-sohn.com/en/shop/proddata-2678.html
Old 25-Mar-2009, 16:31   #13
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Any chance you can bring the scales to Mallory as I'm intensely curious as to the weight of my new race bike!
Old 25-Mar-2009, 16:34   #14
Yes Phil I can bring them to Mallory
On the 21st of June
Old 25-Mar-2009, 16:50   #15
trouty trouty is offline
trouty's Avatar
Mood: i'm a grey dude...
my bike weighs the same as before, but i weigh 2 stones more since this time last season
Old 25-Mar-2009, 17:33   #16
On the 21st of June
I thought you might say something like that!
Maybe I'll magically happen to have a bike in the back of my van when I return your headers
Old 25-Mar-2009, 17:53   #17
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Phil, there's a weighscale in the scrute bay at Mallory.
Old 25-Mar-2009, 17:56   #18
I did not know that! Thanks for the tip.
Old 25-Mar-2009, 20:09   #19
I took mine into work last week to weigh it, so it will be interesting to see how the load cells compare. A light battery and Harriets alum tank I may just make minimum.
Have you got ramps both sides Kev so it can roll on, then roll off, for quickness of getting the punters through.
Old 25-Mar-2009, 21:13   #20
Certainly have Phil, picked them up at lunchtime today
20" ramp each end
44" deck in the middle
and scales that are 12" by 12 1/2"
So ideally suited to a wheel base of 56"
Still some work I would like to do like build a mains to 9v supply into the underside of the deck for powering the scales.
When its finished everything should pack inside the 44" X 13" Deck section with the 20" X 12 1/2" ramps acting as cobers to protect the scales, but that will take time, if I'm lucky I may get the carrying handle fitted before the weekend.
I use to weigh my specials with a load cell at work, I think the 10 Ton crane was a bit over kill though, although it was useful for ploting the rising rate curve after removing the spring from the shock and learning how different shock lengths put you into different parts of the curve
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:49.
