Old 27-Apr-2009, 19:11
hotchillie hotchillie is offline
Bikes: 998s bostrom rep, yamaha r7, yamaha r1sp.
Mood: sustained at the mo
cant select neutral
hi, i have a 748 2000. it has a problem when running cant select neutral and very tight to select into gears. also when running and in first at stand still it is trying to pull forward, as if i havent got the clutch right in.
can any one help.
PLEASE!!!!!!!!
Old 27-Apr-2009, 19:34
As you've discovered, your clutch isn't disengaging completely. Most likely you've got a little air in your hydraulic line so you'll need to bleed it out. All will be well again.
Old 28-Apr-2009, 17:00
ducati dad's Avatar
ducati dad ducati dad is offline
Mood: Older, but none the bleedin' wiser
Or the clutch basket could be loose. I know of it happening to someones 998
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:48.
