Old 06-May-2009, 01:01   #1
badmanners badmanners is offline
Bikes: 748
badmanners's Avatar
Mood: a mix of volterol and vodka
Vista advice sought
My GF's Toshiba laptop had a funny turn and has been sat at the STARTUP REPAIR screen for a few days now.
Nothing I do can get it past this screen, I have F8'd till my fingers bleed, when choosing anything from the SAFE MODE screen it reverts to STARTUP REPAIR and doing its thing.
Can anyone help with this before said Tosh meets with violence?
Many thanks in advance
Old 06-May-2009, 01:29   #2
sadly (or maybe not) - I've never used Vista on a laptop...
Is there an option to boot into safe mode still to try and get it to boot?
Good luck - Frank
Old 06-May-2009, 01:56   #3
Bikes: 748
badmanners's Avatar
Good luck - Frank
There is Frank yes, but alas it takes me to the Startup Repair screen again :-(
Old 06-May-2009, 11:43   #4
Sorry about that....
An option?
http://answers.yahoo.com/question/in...4202630AAyjtkX
Old 14-Jun-2009, 00:51   #5
Bikes: 748
badmanners's Avatar
sorted now
Old 14-Jun-2009, 13:28   #6
Monty's Avatar
Originally Posted by badmanners
sorted now
With a hammer??
John
Growing old-disgracefully!
Old 14-Jun-2009, 14:08   #7
Bikes: 748
badmanners's Avatar
Thankfully no :-)
It seemed to be a problem with Vista (suprise suprise)
I removed the hard drive and connected it via USB to another computer, thus using it as an external HDD.
From there I had to gain access (nightmare) to the user files, copied the files I needed to another HDD. I then couldn't get Vista over the top of the old software so I formatted the HDD, re partitioned and am now awaiting a Toshiba recovery disk before I can start from scratch.
Now my GF backs up her data on the partitioned drive and not the Vista drive :-/
Old 14-Jun-2009, 16:14   #8
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
If you right click 'documents' you can set it's location to the other drive (under location). That'll make it an easier transition.
Also you can use any vista media iirc, not just the laptop CD unless you want all the extras that are installed with it.
You can even switch between 32bit and 64bit vista using the same key.
As with any OEM reinstallation, you'll probably have to phone M$ to activate the installation.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:45.
