Old 14-May-2009, 15:14   #41
couchcommando's Avatar
Mood: ooooh
I can only add I think 620's are **** with **** tyres, that is all
Old 14-May-2009, 15:22   #42
paynep's Avatar
Mood: Wet wet wet
Originally Posted by Chris Wood
I
620's are more on the limit of tyres I agree completely.
Maybe Class A bikes should be on Z rated tyres.........
Old 14-May-2009, 23:37   #43
Otei Otei is offline
Otei's Avatar
I want a go on a 583 now.
Old 15-May-2009, 16:58   #44
phil_h phil_h is offline
phil_h's Avatar
Trolling posts and their associated responses removed
Old 15-May-2009, 19:23   #45
Otei's Avatar
Considering how many people have decided not to race in DD class A this year, where the hell are the bikes, cos I haven't seen THAT many for sale either pre season or during this year?
Hands up if you've still got one under a blanket in the garage!!??
Old 15-May-2009, 19:32   #46
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
well #34 is still on track.
i'd probably still be competing if the alternative was to hide it under a blanket.
Anyway, the bike's getting used AND it's getting a well earned rest at the same time!
Old 15-May-2009, 21:16   #47
DSC Member AK AK is offline
AK's Avatar
got the stuff to put one of ours back to class a if i wanted.
but have moved on these days
Old 15-May-2009, 21:29   #48
NBs996's Avatar
Originally Posted by AK
...but have moved on these days
Which was a big part of the intent of DD... as a stepping stone.
It's been great for me too, even though I'm only bashing things with spanners this year, the 4 seasons of DD has got me well into the world of club racing.
Wouldn't be doing it without the kick start through DSC.
Wouldn't have raced on telly.
Wouldn't have helped staff a WSB meet.
Wouldn't have become a much better track rider (ok, so it's all relative!)
then again, I wouldn't have been lapped by Christian Iddon!!
Old 15-May-2009, 23:21   #49
Imola Duke's Avatar
Conversion of a early 583 engine to bigger valve heads isn't that simple as I understand it, If you have a late 1999 to 2001 583 Monster engine then you can fit the 620 heads and domed pistons, To take it to a full 620 you would need the crank as well.
There is a head on Ebay at the moment for £90, so for a pair of heads, barrels and pistons your probably looking at £250 to £300 providing you have the late engine, by the time you look at adding a crankshaft you may as well be buying a 620 engine (earlier ones are 5 speed later ones 6 speed) prices vary depending on age, mileage etc.
If you could run carbs then you would just need some jetting work done to your old 583 carbs.
The alternative to carbs is fuel injection in one form or another, the original setup with Injector bodies, higher pressure fuel pump, coded clocks, ECU, keys and Harness will set you back a fair bit
There is an alternative of going with a non standard non coded ECU such as a FIM module (not cheap) and you still need the harness for the 5.9M type ECU, throttle bodies, pump etc or you could use a 750SSie ECU with a harness from either the 750SSie/900SSie or the M900ie along with a power commander, pump and throttle bodies
Most people are already runing 40mm pipes so no real cost there.
Then again for those wanting to move into class A there are bikes like Trouty's out there for £2k, you can alternatively buy a standard road 620 for less than that.
Going the carbed 750 route may well have tyre implications as well as the age of the engines and spares availability
some may find this of interest
http://www.bikeboy.org/comp2vmodels.html
750 bottom end, 583 cyls, 620 pistons , 750 heads..............
Old 16-May-2009, 11:01   #50
mjbayley mjbayley is offline
mjbayley's Avatar
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
Smile DD on STEROIDS anyone.....YEAH BABY !!!
Here's my next creation ............
Mmmmmm love those Termi Headers......999 Radial Masters.....Carbon Loraine brakes..........mmmmmmmm....
What you think peeps.....(and all done on the 'Dole' as it used to be called!)
Marko
Click image for larger version Name:	DDonsteriods1A.jpg Views:	136 Size:	244.7 KB ID:	10700  Click image for larger version Name:	DDonsteroids2A.jpg Views:	130 Size:	183.8 KB ID:	10701  Click image for larger version Name:	DDonsteriods3A.jpg Views:	132 Size:	226.4 KB ID:	10702  Click image for larger version Name:	DDonsteriods4A.jpg Views:	129 Size:	203.0 KB ID:	10703
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:40.
