Old 21-May-2004, 17:56   #11
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
hi chillo
i had the same problem on mine when it was new so i fitted the rear spring from the 999s bp and the difference on hi speed long corners was amazing (i weigh 96kg if that helps.....)
Old 22-May-2004, 01:46   #12
ducv2 ducv2 is offline
Mr Rottweiller, that was'nt you at croft, Friday May 7th by any chance??
Old 23-May-2004, 15:19   #13
chillo chillo is offline
chillo's Avatar
i've moved the seat forward as far as possible which has helped a little. But it turns like a bus still, going to dial in some more rear ride height and possible a bit of rear comp.
Old 23-May-2004, 23:48   #14
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Just fit some carbon rims...... hey presto.... job done.
Old 23-May-2004, 23:55   #15
nathanhu's Avatar
Mood: head down
done that.....................
still handled and turned like a old boat compared to my old 996 until i changed the rear spring that is....
Old 23-May-2004, 23:58   #16
dave w's Avatar
Did you not find it helped...... what type did you go for?
Old 24-May-2004, 00:08   #17
nathanhu's Avatar
Mood: head down
hi dave.
ive got a front from my 996 from dymag (full carbon) and fitted it to the 999 with the discs from a 99#r
the difference was amazing after the bike had been a bit better set up, stonger spring on the rear and more ride hight
one problem i incountered with the carbon rims is thst the tyres have a habbit of turning on the rim under heavy braking.... thus spinning out of balance, realy annoying evry 20 sesion re-balancing tyres..
Old 24-May-2004, 00:16   #18
dave w's Avatar
Only had that problem with the rear spinning up on the rim..... what a pain !!...... I put a dot on the tyre now..... when you next change your tyres try fitting them up dry..... works for me .
Old 24-May-2004, 02:53   #19
chillo's Avatar
2 full turns of ride height has made a big improvement. I don't plan on changing the rims as they are the black forged type, 57mm system + PC3usb will be going on first.
still getting a little bit of movement at high speed (130+) when cranking it over, could be the aerodynamics
Old 24-May-2004, 17:46   #20
dave w's Avatar
Funny that feeling at speed ....... bit like sitting on a seesaw...... going to get mine fitted with active yaw control...... that might help !!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:08.
