Old 02-Nov-2009, 00:20   #1
pbrown pbrown is offline
Poor running problem then got better?
Just done a trackday on my bike & everything was working really well then in the afternoon it cut out 3 or 4 times while in the pit lane waiting to get on track. Once on track it would not rev above 5000rpm & felt very rough or maybe only running on 1 cylinder getting worse the more I tried to rev it.
Came straight into the pits, gear off & started bike to see if I could maybe find anything & it was working fine so went straight back out again. I had no further problems so I am left wondering whether it was just a glitch or the start of something electrical going wrong. I had no warning lights on the dash.
Has anyone had the same kind of problem & is it a known issue?
Old 02-Nov-2009, 00:29   #2
Check all connectors are tight especially the large onethat connects to the ECU.
This year at the DSC Cadwell trackday my 996 would just die after I had used it in a wet session, never did find out what that was as it was fine when I got it home and has since been out on quite a few rideouts and runs to work
The Year before I had a lack of power that was caused by a blocked fuel filter which is what happens when you leave your trackday tank standing for to long
and a few years ago again at Cadwell we thought Dallas's 996 had a ignition pickup problem but that was traced to the main ECU connector working loose
Old 02-Nov-2009, 09:15   #3
I was going to go round & check the connectors but not sure I would have done the ECU as it looks like it shouldn't come loose.
My 996 was always cutting out but wasn't cured by turning it on & off. That was down to a bad connector on the side stand relay.
Old 02-Nov-2009, 17:50   #4
DSC Member final_edition final_edition is offline
final_edition's Avatar
Mood: Having some tinnies and a barbie
My 998 was cutting out on a trackday. It was traced to too big an air gap on the ign pick-up sensor.
Old 02-Nov-2009, 17:52   #5
Was it cutting out all the time or just intermittantly?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:39.
