Old 05-Feb-2010, 23:13   #21
kenoir kenoir is offline
kenoir's Avatar
It seems I'm having a similar problem. I've gor a 900ss ally swing arm (in the 600ss frame) but the rear wheel is a later addition with a 25mm bearing (my spindle it 17mm).
Does anyone know if it's possible to just replace the wheel bearings from 25 down to 17?
Old 05-Feb-2010, 23:21   #22
Yes you can the bearings are approx 2mm wider which isn't a prob you just have to adjust the external spacer's slightly. Its what I have done with mine.
Old 06-Feb-2010, 00:37   #23
As Phil says the answer is yes
replace the existing original fitment bearings which are
75162.2566 = 6005 2RS C3 47 X 25 X 12
with 6303 2RS C3 bearings which have the dimensions 47 X 17 X 14
http://cgi.ebay.co.uk/SKF-Rubber-Sea...item334a14c3ea
As Phil pointed out they are 2mm wider but have the same Outside Diameter and will fit the 17mm spindle
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:43.
