Old 30-May-2004, 11:11
everton
Torque settings for 999
Anyone know of a definitive list of torque settings for the 999, specifically the 999R.
I'm looking at settings for:
Front & rear wheel nuts, i.e. I have 180NM for the rear wheel nut
Rear sprocket nuts
etc, etc, etc...............
Old 30-May-2004, 11:48
The front is probably the same as the ealier bikes. 67Nm +/- 5Nm.
I'd go for 43Nm on the sprocket nuts.
sorry, don't have the manual with me
Old 30-May-2004, 12:00
everton
Cheers Neil,
Expectant of a wet BH Weekend I'm doing some detailed cleaning & degreasing
The rear sprocket is shocking.
Any advice on a good degreaser. Also, if I remove the sprocket from the wheel is there an order in which I should torque up the 5 nuts..........going round opposite to opposite??
Old 30-May-2004, 12:09
If the sprocket is off the bike you can't beat Gunk or Jizer. They're too strong though to use when in situ around the chain. Not good for the grease in the pins.
Muc-off or Wurth is good for general cleaning. work it a little with an old toothbrush if it's stubborn.
When you refit the sprocket, nip everything down in a star pattern, then torque up in the same way.
Have fun
Old 30-May-2004, 12:38
everton
Sprocket's off.............you sure they're only torqued to 43..............phew!!
I'll give the sprocket a good soak andclean up round the cush...etc
Same torque settings for the rear disk???????????
Should be looking good for the next Berks/Oxon meet next Sunday
Old 30-May-2004, 13:34
Hey Everton, you not going to takethe opportunity of a larger rear sprocket then? 38??
Im doing this this week, obviously needed a longer chain so ive gone for a gold erv2, and ill lengthen the wheel base aswell while im at it.
have fun.
Old 30-May-2004, 20:10
nathanhu's Avatar
nathanhu nathanhu is offline
Mood: head down
andyb the 38 tooth fitts with the standard chain and shortens the wheel base
Old 30-May-2004, 21:28
dave w's Avatar
dave w dave w is offline
Mood: My K5 Rocks !!!!
Andy..... 38 rear..... 14 front works for me
No more links needed...... just a new soft link
Old 30-May-2004, 21:37
nathanhu's Avatar
Mood: head down
why do you need a new soft link?
Old 30-May-2004, 21:44
dave w's Avatar
Nathan....... when you remove the front sprocket you have to split the chain as there is no clearance to remove it...... Hence new soft link.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:02.
