Old 22-Apr-2011, 15:35   #1
Any ideas how to undo the lower shock bolt
As per the title
Been struggling for a couple of hours to undo the lower shock bolt on my 1100 Monster, tried the air gun and 600mm long breaker bar and all I have managed to acheive is two spiral 8mm Hex keys and a marked footrest casting and the bolt is still solid.
The bike is less than 2 years old has less than 9k miles on it and wasn't used through the winter.
Old 22-Apr-2011, 15:54   #2
Decided to try the 750mm breaker bar and a 3rd 8mm Hex Key
Managed to shear the Hex Key, so the costs of trying to undo this one bolt is mounting up
Maybe I should see if I can get the bolt replaced under the warranty, although that doesn't help at the moment and at the same time see about the alloy corosion on the front headlight
Old 22-Apr-2011, 21:36   #3
Did type a follow up thanking Kev P for his help
Then when I posted the reply I got the Sit Busy message and lost it in the ether
Old 22-Apr-2011, 21:39   #4
dunlop0_1's Avatar
It sounds daft Kev but, left hand thread ?
Stranger things have happened.
Old 22-Apr-2011, 22:00   #5
Well now I have seen it all. Skids posting up a "How do I"
I have lived.
Old 23-Apr-2011, 01:06   #6
Nope Neil not a left hand thread, not even a nut to worry about
A 10mm Bolt passes through the swingarm casting through the shock eye and threads into the swingarm on the other side.
Craig it pretty much turned out to be a two man job, what should be a fairly simple job is made a lot harder by Ducatis use of nickle plated Steel bolts and fitting them into alloy without the use of any anti-seize compound.
Kev P came around with some more 8mm Hex keys which we then managed to trash including the Snap-on one
In the end we got it out with me heating the swingarm with the heat gun adjacent to the thread area and Kev attacking it from the other side with the Windy gun
Once the bolt was removed there was no sign of either thread-lock or Anti-Seize compound. So the problem was caused by corrosion, needles to say when I refitted the bolt after cleaning it with scotch-brite I gave it a liberal coating of copper slip
So the answer to the original question is
Six 8mm Hex Keys required
Windy Gun required
10 Bar Compressor required
Heat Gun required
Two people required
And how ever long it takes
Old 23-Apr-2011, 07:59   #7
Loz Loz is offline
Loz's Avatar
I too love the steel bolt, alloy combo.
Undoing something or other (footpeg?), the other day, I needed a breaker bar arrangement on the allen key ... the thing finally let go with an ear-splitting crack and a distinct spark. A spark! Crazy.
Old 23-Apr-2011, 12:25   #8
DSC Member AK AK is offline
AK's Avatar
am glad my suggestion to senna when he phoned worked then skids
Old 23-Apr-2011, 19:00   #9
Yep Alan
by the time Kev phoned you we had tried everything bar the heat, mainly beacuse I didn't want to damage the finish on the swingarm.
But as you suggested you can't do it without it,
do you report these sort of issues back to the Factory or Ducati UK or just live with it.
Old 25-Apr-2011, 00:50   #10
Only a slight mark left on the swingarm from the heat gun
So I may have to go for a nice Carbon swingarm protector
http://www.motochepassione.it/PARTI-...NSTER-1100.htm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:24.
