General Motorcycles only
Old 27-Aug-2011, 19:49
figaro's Avatar
figaro figaro is offline
Bikes: Triumph Sprint ST 1050; Suzuki SV1000S
Mood: Mostly hungover
Dodgy LCD speedo
I've just bought a 2003 Multistrada, and the lcd display is faulty. A load of the pixels don't show, but otherwise it works fine. Is there anything that can be done to save the display, or is it scrap now? I dare say a new one will be prohibitively expensive, and I've not seen a secondhand one for sale yet, so I'm hoping it's salvageable. Any advice welcome.
Old 27-Aug-2011, 21:52
I've seen quite a bit on this, apparently its because the reset buttons are pressed too hard
not seen any fixes I'm afraid
Old 27-Aug-2011, 22:04
figaro's Avatar
I've been scouring the internets and can find nothing. Maybe I should look at an aftermarket setup, there are some pretty flash units available for small money these days, though I bet they're a pig to wire up.
Old 27-Aug-2011, 22:17
why bother? maybe look out for a 2nd hand replacement but other than at night its not an issue
Old 27-Aug-2011, 22:28
figaro's Avatar
I can't read the speedo very well during the day (I've only just got the bike, so not ridden it at night), and the mileometer is totally unreadable, which I suspect is an mot issue.
Old 27-Aug-2011, 22:47
Be careful with replacement units as the clocks are coded to the keys and in turn the ECU is normally coded to the clocks. So fitting a second hand set is likely to cause you more problems
If I recall correctly there was a company that fixed these sort of things, not sure of the name but Scorpio seems to ring a few bells
figaro's Avatar
Ah. It would appear there's also no backlight, so it's unreadable in the dark.
Old 27-Aug-2011, 23:00
figaro's Avatar
I've just found it; Scorpio Electronics, cheers. I've emailed them. The other option as I've said would be replacing it with an aftermarket unit, but would removing the unit cause any problems with the coded ignition?
Old 27-Aug-2011, 23:12
Yes
As the Clocks decode the transponder in the Key and then send a signal to the ECU, replacing the dash with a after market unit would immobilise the bike
There are ways around this such as having the ECU reprogrammed so that it doesn't look for a code, not sure how much they charge for this service. i'm sure Mark at BSD could give you a quote.
Replacing the complete set isn't cheap, think there are some clocks, ECU and Keys on ebay for around £500
Be better if you can get yours repaired
Old 28-Aug-2011, 10:59
ar OK can see why they need replacing/repairing then
post if you find one; think you may be doing lots of numpty riders a service
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:30.
