Old 26-Sep-2011, 23:37
No Steve the Oil temp sensor in the front rocker cover of the 620 does the same job.
to go with the 1.6m ECU You would need the 748/916/ST2 harness, MAP Sensor and Air Temp sensor
Old 26-Sep-2011, 23:42
Imola Duke's Avatar
Thats good news then! i have a st4/2 1.6m ecu and harness complete in my shed!
Ecu has a ducati performance ST4 eprom fitted at the moment.
Old 26-Sep-2011, 23:56
The 4.5mm longer stroke of the ST4 may cause ignition timing issues, but then again the EPROM may have a advance curve that works, hard to tell until its tried.
As for fueling which injectors did the ST4 use was it the green ones, if so a Powercommander should easily be able to sort out the air/fuel ratio.
Only other concern is the TPS as the connector is different but the signal should be OK as the Mathesis can test both
Old 27-Sep-2011, 22:25
Imola Duke's Avatar
Thanks Kev
Prob easier to get hold of a st2 harness.
Good thing about 1.6m is you see lots of s/h pc3's up for sale for this type ecu.
Old 11-Nov-2011, 23:21
Imola Duke's Avatar
After a busy period at work as you know Kev! We will meet so you can collect to forks
Questions!
1.6 ecu fitted with st2 eprom and fit PC3 ?
st4 loom (with green injectors) can be used on the 2v injector bodys/injectors ?
The st4 loom complete with MAP and Air temp sensor will work on a 620 engine ?
Hope this makes sense ? Just finished a nice bottle of red
Old 12-Nov-2011, 17:28
Steve, injection ECU doesn't give a dam which engine is in the bike, all it cares about is having Suitable impeadance injectors, suitable TPS, suitable engine pick-up, suitable air temp sensor, suitable engine temp sensor, suitable MAP Sensor (some ECUs do this differently), Suitable harness and correct resitance coils.
Then its just a matter of having a fuel and ignition program loaded into the ECU or EPROM (possibly aided by a PC3) to suit the choosen engine
So I would suggest a 748 EPROM if using a 1.6M ecu as the engine uses the same stroke as a 620, I would also go with ST2 or 750/900ie green injector throttle bodies and TPS, the latter is the same TPS as used on 748Rs so works with a 1.6M ECU
And in answer to your email, yes I still have a 620 engine available
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:32.
