Old 20-Jan-2012, 00:12   #1
748 trumpets - what size?
I want to get some pod filters top drop over the ones being fitted to my TBs but dont know what size diameter is needed. Thinking about something like this
http://www.ebay.co.uk/itm/RAMAIR-Mot...#ht_1670wt_853
its only for racing so looks unimportant - just protect the engine
Old 20-Jan-2012, 07:44   #2
dunlop0_1's Avatar
O/D 57mm I/D 50mm
Old 20-Jan-2012, 10:50   #3
Thanks, so I'm looking for a set which are 57mm
Old 20-Jan-2012, 10:55   #4
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Are you not fitting ram stacks Paul?
Old 20-Jan-2012, 10:57   #5
er - I am fitting 748 bell mouths if thats the same thing?
Old 20-Jan-2012, 11:06   #6
Bikes: 916 Strada
Chaz's Avatar
That's what I ment, you will need to be carful not to spoil the effect of the stacks with the filters, it's really something you should setup on the dyno as it will have a huge effect on the fuelling.
Old 20-Jan-2012, 12:50   #7
Cranker V2's Avatar
Mood: Green with envy
Im using 748 velocity stacks Paul, with just a coarse mesh protecter to prevent ingress of sparrows, lumps of brick , kitty litter etc.
Old 20-Jan-2012, 13:45   #8
lots (incl engine builder) have warned me against mesh or no filters as too much fine debris will mean engine rebuild come mid season. I was going to use bodywork mesh originally
Old 20-Jan-2012, 13:54   #9
Bikes: 916 Strada
Chaz's Avatar
It's only top end though, its all a trade off, if you fit restrictive filters you may as well keep the air box IMHO.
Old 20-Jan-2012, 14:02   #10
Cranker V2's Avatar
Thats all I will be using, same as on 853r. No filters but knowing wear will be increased and potential for sucking in debris in an off.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:40.
