Old 22-May-2012, 15:34   #1
ells ells is offline
ells's Avatar
Simples front sprocket question
Numpty here took off the front sprocket today but got distracted and forgot which way round the sprocket goes.
Either flat face of the sprocket facing the engine which moves the cahin in at the front or flat face facing outwards keeping the chain away from the engine.
Please help as I am out on the bike tomorrow and know I have already managed the wrong way once.
Thanks
Mark
Old 22-May-2012, 17:49   #2
Depends on the bike Mark, My 583 SS had the flat side out. This 620ie has the flat side in.
Just straight edge it from your rear sprocket, you can sight the chain also, unless you have a pi55ed up eye.
Old 22-May-2012, 18:31   #3
PM sent
Old 22-May-2012, 19:24   #4
Normally in imprint on socket where it's had the plate fixed
Old 22-May-2012, 22:35   #5
ells's Avatar
Unless you are a double numpty and the inprint is from the last time you did it wrong.
Old 23-May-2012, 22:29   #6
Cranker V2's Avatar
Mood: Green with envy
You went well today Mark, looks like you got the sprocket on the right way.
Old 24-May-2012, 08:09   #7
ells's Avatar
Thanks Mike,
Last session went well. Not quick enough but better than last year. Still not convinced about the sprocket. Bits of swarf round the sprocket so will have a good look at it before I use her again.
Thanks
Mark
Old 24-May-2012, 09:12   #8
So where was the testing this time Mike...bit of Angelsey prep or Oulton cheeky few few sessions
Old 24-May-2012, 12:07   #9
ells's Avatar
As per last year no Anglessey this year again for me. Serious Oulton prep yesterday both for DD and for something else as well
Quite a few thundersprts guys out as they are there this weekend. The fast group was frightening quick.
Still a lot of work to do before mid June. Still not quick enough and not consistant enough!
Mark
Old 24-May-2012, 14:06   #10
Long as steps are forward, at some point you start taking 2 at a time and everything makes sense. Bike working well then....
Not sure about Oulton myself, probably will but who knows...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:56.
