Old 07-Oct-2012, 19:01   #1
dunlop0_1's Avatar
Are these race pads worth the money?
Just short of £200 a set
Still thinking about it though.
http://www.ebay.co.uk/itm/2609140189... 4.m1423.l2649
Old 07-Oct-2012, 19:25   #2
In a word, No.
part number is 762DS, just google it.
http://www.coatesmotorcycles.com/762...rake-pads.html
https://www.ducatimondo.co.uk/store/...00r-762ds.html
Old 07-Oct-2012, 19:56   #3
dunlop0_1's Avatar
Cheers Chris.
Old 07-Oct-2012, 19:57   #4
Just sent you a text Neil.
Old 07-Oct-2012, 20:56   #5
Depends what your going to use them for, if your using them for racing and have Brembo Superbike discs or equivalent 6mm thick discs then yes they are probably worth it.
If your going to be using them in anger and getting the most from them with thinner disc and end up warping the discs then probably not.
And for road use the answer to your question is No
Old 08-Oct-2012, 05:26   #6
dunlop0_1's Avatar
Yep thanks Phil.
Kev I was thinking of the using them in the 996 next year.
When I rode the 1198 at Oulton it had (I think) PZ4 pads? I know the calipers are different to the 996 but the stopping pwoer was awesome. I know some use them in the 848.
Just want to try and improve the 996.
Old 08-Oct-2012, 08:52   #7
The RSV4 I had off Dallas had Brembo Z04 pads along with Brembo Stainless Superbike discs (6mm Thick), which he bought after talking to Neil Appleton at Bike Torque who I use to race against in Sound of Thunder.
Neil warned about disc warpage under race conditions with lesser discs and judging by the amount of warped standard Aprilia RSV4 discs Dallas had it is often an issue.
Ideally Brake Pad Material should be matched to the Disc Material
Old 08-Oct-2012, 10:51   #8
dunlop0_1's Avatar
That makes sense. So I am I looking at cast iron discs?
Old 08-Oct-2012, 12:41   #9
I have a pair sat at home, not sure if they are semi or full floaters though?
Had them as trackday discs, but since doing the radial fork and caliper conversion they I need the 15mm offset discs, so they are now redundant.
Old 08-Oct-2012, 14:20   #10
dunlop0_1's Avatar
Might be intrested. PM me a price.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:45.
