Old 02-Jan-2013, 22:56   #21
Originally Posted by Yogi
**** in the tank !
That might just help, especially after a good Jalfrezi.
Old 04-Jan-2013, 19:38   #22
Looks like all the issues are down to the CAN (Mpre like CAN't) system, stick a DECODED and remapped 620 ECU on it and wire in a MAP/AIR Temp sensor and its all Hunky Dory
Old 04-Jan-2013, 22:37   #23
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
.....well, for the time being at least.....
Old 04-Jan-2013, 23:44   #24
Quite right, it will be revisited in the future, wish I could get new pins for the ECU connectors that way I could build a nice custom harness that could incorporate the wiring for the standard 620 setup and also the Dual CAN system.
Maybe when I get around to building my Class A Monster I will have another try, in the meantime I need to get this bike ready for Phil, so tomorrow I'll be adding a Tacho out wire to run the Rev Counter
Old 05-Jan-2013, 09:52   #25
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Skids
I've got loads of wires with the connectors on that are left over from my 'ECU Writer Connector' builds. PM me your address if you want some.
Old 05-Jan-2013, 18:13   #26
Thanks for the offer Chris, I already have a few used wires with the ends on but would like some new ones that I can crimp on to new wires
I think I may have found some that are suitable, well about 4 different ones so need to get a few samples of each in and see which are best to use
Old 05-Jan-2013, 19:08   #27
chrisw's Avatar
Connector pins
These should help
http://uk.rs-online.com/web/p/automo...3D4E4 F4E4526
or
Old 05-Jan-2013, 21:36   #28
Cheers Chris thats the ones and as I have a registered account with RS I've ordered some
Three of the ones I came across last night were Molex, not suprising as they bought out Cinch
And another couple were Bosch as they make an identical connector
Old 05-Jan-2013, 21:45   #29
chrisw's Avatar
Do you have a cheap source for the actual connectors? Would save me deconstructing Fiat Punto looms.
Old 05-Jan-2013, 21:57   #30
Sadly not Chris, I'm doing the same as you, recycling used ones, some Fiat Some Ducati. Which is OK as I'm mainly modifying Harnesses for track bikes, but would like to get hold of some cheap new ones then I could make convertors for 1.5M ECUs etc
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:06.
