Old 18-Jan-2013, 11:50
r15suk's Avatar
r15suk r15suk is offline
998 brake hoses on 996?
In the process of replacing the calipers on my 996 BIP with 998 ones.
Obviously i need new brake lines so my question is - will 998 twin line ones be the correct length for my 996 or will i need to get set custom made?
cheers
Simon
Old 18-Jan-2013, 13:30
ones for a 998 should fit OK,
I take it you mean your fitting 998S/998R calipers as the 998 Bip ones are the same as the 996 Bip.
Mastercylinders are also the same
Old 18-Jan-2013, 15:22
r15suk's Avatar
Yes the 4 pad ones.
Simon
Old 31-Jan-2013, 22:34
r15suk's Avatar
So would you say that is was these ones;
http://helperformance.com/store/prod...oducts_id=3974
and not these ones?
http://helperformance.com/store/prod...oducts_id=3931
They are both two line ones and are the same price, so would the difference be the type/angle of fitting and/or the length of the line?
Simon
Old 01-Feb-2013, 00:01
It will be the ones for the 998S, the 998BP 2-Pad calipers with the two retaining pins have the banjo bolt screw in from the top. the P4 4-Pad calipers on the 998S have the banjo bolt screw in from the side, which means the lines are a little longer and the Banjos are at a different angle
Old 01-Feb-2013, 13:08
r15suk's Avatar
Thanks for the info. I'll order the S ones then.
Simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:25.
