Old 13-Feb-2013, 22:47   #1
Campo Campo is offline
Bikes: Class B 600ss #99
Campo's Avatar
Engine oil?
I'm sure i was reading a post on here not long ago about which engine oil to use but I can't seem to find it in the search. I've just been looking through the Haynes manual and it says to use fully synthetic oil but I'm sure I've read a few of u guys having problems with the clutch slipping so should I be putting semi synthetic in instead?
Old 13-Feb-2013, 23:15   #2
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
I've used both without problems. Use good quality oil. Suggest 50w at the upper end, because its going to get very hot and you'll be warming it up before you race (not like riding it straight out of the garage on a cold morning!)
Old 13-Feb-2013, 23:23   #3
based on personal experience I stay away from the fully synth oil in my DD bike with its standard style clutch after initially experiencing clutch slip on my 620
opting for Silkolene 15W50
Old 13-Feb-2013, 23:30   #4
Campo's Avatar
Ok chaps thanks for the advise. I'm sure I will have many more novice questions to come
Old 14-Feb-2013, 06:26   #5
Used fully synthetic in class B bikes over the past 6 years without problem, but a 620 will slip with it in, so used semi synthetic.
Old 14-Feb-2013, 10:56   #6
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I was talking to Neil Spalding the other day about clutches as you know he's Sigma clutches, my question was if you can run an 848 wet clutch on fully synthetic with no slip, why can't you run the same oil in the 620? Simple answer there are less plates in the 620 so less friction area.
I've tried to use fully synthetic several times without success, on the dyno the clutches all start to slip around 60bhp so I use 15/50 semi & change it every meeting.
I know some will say they use fully synth I'm sure they do! They must be very kind on the clutch
Old 15-Feb-2013, 10:53   #7
Good source of oils here:
http://www.smithandallan.com/
they also use Ebay.
Old 20-Feb-2013, 23:41   #8
Campo's Avatar
Thanks for the replies. I take it 10w40 is no good for racing?
Old 21-Feb-2013, 07:24   #9
Seems that some full synthetics cause more problems than others. I used Shell Ultra in many DD bikes with no problems. Motul 7100 seems to work ok to. Full synths from silkoline and putoline appears to slip......
A lot can depend on the condition of your clutch to.
Old 21-Feb-2013, 09:04   #10
bally71's Avatar
Mood: Inquisitive cat
i use shell ultra fully synth .. used it in th 800 too
got slip with a standard clutch .. fitted a barnett hd clutch and no slip
i just thought it was the standard clutch not up to it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:24.
