Old 21-Feb-2013, 22:07   #1
r15suk r15suk is offline
r15suk's Avatar
Front Mudguard Removal
Hi,
I have just tried to remove the front mudguard from my 996. The two bolts on one side were no problem but on the other side it appears that the captive nut in the plastic clip that goes round the fork leg is spinning round with the bolt.
Whats the best thing to do? Cut the clip off and replace it and keep the bolts lubed with copperslip? Is this a common problem?
Simon
Old 21-Feb-2013, 22:35   #2
Yep common problem, sometimes I crush the plastic onto the captive nut with a set of pipe grips, doesn't always work, but often does.
Copper slip is a must on reassembley
Think new ones were about £8 each last time I purchased some
Old 23-Feb-2013, 18:53   #3
r15suk's Avatar
Cheers for the info. Snells keep them as a stock item so i'll be getting a couple and be £16 lighter
Simon
Old 24-Feb-2013, 14:55   #4
Yep, as Kev said - I ended up buying new rings when taking the forks off my ST4s.
I replaced the bolts with stainless to rule out rusting as well.
Old 24-Feb-2013, 17:19   #5
r15suk's Avatar
Good idea :-)
Lucky for me it was only two that needed to be replaced and not all four.
cheers
Simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:21.
