Old 13-Apr-2013, 11:41
Campo's Avatar
Campo Campo is offline
Bikes: Class B 600ss #99
Kill switch again
I've just had another look at my kill switch and if the kill switch is in off position before the main power switch is turned on the bike won't start which is telling me the kill switch is still connected but once the engine is running the kill switch will not kill the engine. Anyone have any ideas as to what could be wrong? Any suggestions will be appreciated
Shane
Old 13-Apr-2013, 12:32
dunlop0_1's Avatar
Are you still using the key and barrel or a switch?
Old 13-Apr-2013, 12:52
Campo's Avatar
Just a switch
Old 13-Apr-2013, 13:22
dunlop0_1's Avatar
So the bike will only stop when the ignition switch is off. Lecy aint my strong point but it may be possible that the ignition relay when energised is staying latched in even when the kill switch is turned off.
Change the yellow relay for a start.
Old 13-Apr-2013, 14:41
Campo's Avatar
Yep bike will only stop when ignition is switched off. I will try the relay I'm just gonna have to do a process of elimination I think.
Old 13-Apr-2013, 15:38
SeeleyG50's Avatar
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
Mood: The Older I get the Faster I Was!
Good plan
Old 13-Apr-2013, 23:56
The Kill switch shouldn't have anything to do with the Ignition Relay.
Normally it is wired so that one side of the kill switch is wired to +12v from the fuse box and then when in the ON position it puts that 12 volts feed onto the Coils and Ignition modules, so when its in the OFF position there is no voltage to the coils or ignition modules hence stopping the bike running.
Old 14-Apr-2013, 00:12
Campo's Avatar
If I switch the ignition on without starting the bike up I can hear the fuel pump turning on and off when I flick the kill switch on and off. But if I start the bike up the kill switch has no affect.
Old 14-Apr-2013, 00:19
That's odd as the same 12 volts that goes from the fuse to the kill switch also goes to the fuel pump and therefore the fuel pump should only be controlled by the Ignition Switch and not the Kill switch
Sounds like the ignition On feed is going to the Coils and ignition Modules and the Kill switch ON feed is going to the fuel pump
So they are the wrong way round
Old 14-Apr-2013, 10:50
Campo's Avatar
Yeah is strange even when it's running I can hear the kill switch cutting off the fuel pump but the bike keeps running.
I think I will just take it to someone who knows what their doing whith electrics
Thanks anyway for the suggestions
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
