Old 28-Apr-2013, 13:43   #11
The strainer is under the plug that is beneath the clutch cover. When that plug has been removed and the oil let loose, you will need a 14mm Allen key to extract the strainer. Its a tubular fine gauze in nylon and about 120mm long and 22mm diameter.
Old 28-Apr-2013, 13:52   #12
I think the one on Jim's is attached to the bolt head so it's a one piece not two piece version.
Old 28-Apr-2013, 22:22   #13
Bimjob Bimjob is offline
Bikes: Yamaha R1, Ducati 600SS
Thanks I didn't know about that. So this strainer should be replaced at the same time as the oil and filter?
Old 28-Apr-2013, 22:58   #14
No, it just needs removing and cleaning with brake cleaner, just check it for swarf as well.
Old 29-Apr-2013, 07:02   #15
dunlop0_1's Avatar
Originally Posted by Jonzi
Evening
Is there any thing else that I should do between races?
More track days.
Old 29-Apr-2013, 08:18   #16
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
Originally Posted by Spjallen
Oil every meeting. Filter every other including the strainer.
That's a shocking waste of good oil Si
Unless you are then using it for Salad Dressing?
Old 29-Apr-2013, 15:21   #17
bally71's Avatar
Mood: Inquisitive cat
hatch a cunning plan
Old 04-May-2013, 19:35   #18
Yogi Yogi is offline
Yogi's Avatar
Found it !
It's under the temp. sensor housing nut (21mm) situated just under the clutch casing.
There is also a drain bung directly below it, accessed form underneath.
Old 05-May-2013, 10:49   #19
Originally Posted by Yogi
Found it !
Err, told you that in post #11.
Old 05-May-2013, 14:15   #20
Yogi's Avatar
It has to be spelled out in fine detail for us thick Northerners.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:35.
